It Never Rattled Before
Old Jun 1, 2005 | 05:15 PM
wolfmd's Avatar
wolfmd
Default It Never Rattled Before
I've noticed that the more frequently I have my targa top off, the more it seems to rattle when I put it back on. Is this a common issue with the targa top?
Old Jun 1, 2005 | 05:37 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
I take mine off and replace it at least 3-4 times a week and have not experienced this.
Do you lubricate the rubber molding with the top off regularly? I wipe a silicone spray onto a rag and then use that to wipe the moldings at least once a month if not more. Roof is as quiet as it can be.
Old Jun 1, 2005 | 05:38 PM
vetterlatethannever's Avatar
vetterlatethannever
Might have to try that, not for noises yet but just preventive maintenance. Thanks!!!
Old Jun 1, 2005 | 05:48 PM
KHM_70's Avatar
KHM_70
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
No problem here. . .
Old Jun 1, 2005 | 10:58 PM
cvn's Avatar
cvn
I've just started experiencing the same problem. Can't seem to stop the rattle. Applying pressure to the top in the area the sound "appears" to be coming from doesn't stop it.
The top was never removed by the previous owner. After taking on and off approximately 30 times now, the rattle has started.
Old Jun 2, 2005 | 06:23 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
Had the same thing happen to the better halfs 04. Sounded like a dash rattle. Took it my vette tech and he adjusted the retainers. No problem now.
Old Jun 2, 2005 | 06:33 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
I chased down a rattle in a newly installed glass top this weekend, drove me nuts for awhile. Would rattle and pressing/holding down on and/or applying pressure would not stop it. It turned out is was not an up/down rattle, but rather a forward/backward rattle, if that makes any sense. The clamp base on the roof was too close to the striker plate on the windshield and they were moving back and forth, hitting each other. I loosened the torx bolts on the clamp on the top, moved it back about an 1/8 of an inch and no more rattle.
Patches from this forum sent me a doc on the 5 adjustments you can do to roof panel, pasted below:
Roof Lift Off Panel Adjustment
1. Perform one or more of the following five adjustment procedures to properly align the roof lift off panel.
2. To adjust the front striker for up down roof alignment perform the following steps:
3. Remove the windshield upper garnish molding. Refer to Windshield Upper Garnish Molding Replacement in Interior Trim.
A. For major up down roof adjustment loosen the striker bolts and reposition the latch striker up or down.
B. For minor up or down roof adjustment loosen the striker outboard bolt and slightly loosen the inboard bolt, pivot the striker on the inboard bolt in 2 mm (0.08 in) increments up or down.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
C. Tighten the striker bolts. Tighten
Tighten the roof front latch handle striker bolts to 10 N•m (89 lb in).
D. When the striker is properly adjusted the handle will snap closed.
4. Install the windshield upper garnish molding. Refer to Windshield Upper Garnish Molding Replacement in Interior Trim.
5. To adjust the front latch handle forward or rearward perform the following steps:
. Loosen the latch handle bolts.
A. Position the latch handle forward or rearward. Maintain a minimum of 2 mm (0.08 in) clearance between latch handle and the latch striker to avoid squeaks and rattles.
B. Assure the latch handle base is parallel to the striker to provide clearance to the sunshade mirror door.
C. Tighten the latch handle bolts. Tighten
Tighten the roof front latch handle bolts to 13 N•m (10 lb ft).
6. For major rear latch adjustment adjust the rear latch striker performing the following steps:
A. Remove the roof lift off panel.
B. Remove the roof bow center interior trim panel. Refer to Trim Panel Replacement - Rear Roof Bow in Interior Trim.
C. Loosen the rear latch striker attaching bolts.
D. Adjust the position of the latch striker forward or rearward for major adjustment.
E. Tighten the striker attaching bolts. Tighten
Tighten the roof rear striker bolts to 10 N•m (89 lb in).
F. Install the roof lift off panel.
7. For minor rear latch adjustment, adjust the latch handle hook one turn at a time to achieve moderate pressure to the latch as follows.
A. Loosen the set screw locking the latch hook.
B. Turn the hook in to tighten or out to loosen.
C. Tighten the set screw.
D. Install the roof panel.
8. To adjust the rear locator perform the following steps:
. With the roof installed on the vehicle loosen the locator mounting bolts.
A. Reposition the locator.
B. Tighten the mounting bolts. Tighten
Tighten the roof rear locator to locator bracket bolts to 10 N•m (89 lb in).
© Copyright General Motors Corporation. All Rights Reserved.
Old Jun 2, 2005 | 03:22 PM
wolfmd's Avatar
wolfmd
This is good info. I have also tried pushing up on the roof and the rattle continues. I'll check out the front-to-back motion for the rattling.
Thanks for all your input. This is the only place to go for advice
Old Jun 2, 2005 | 04:55 PM
ericdwong's Avatar
ericdwong
Agree with the above posts. Try to adjust it. Thats what I had to do.
Old Jun 3, 2005 | 01:05 PM
I've not had this problem with mine. May want to check the latch area for tightness.
To It Never Rattled Before
