Wheel guys: BIG BRAKES BIG PROBLEMS!
Wilwood couldnt offer any help as well
If im not being clear enough, its the spokes hitting the calipers(depth problem)
The problem with the 1pc 505's, is they were made to maximize the lip size for appearance reasons. Big lip=little caliper clearance, no way around it.
Dramatically changing the caliper clearance on a 1 pc wheel would pretty much involve a total redesign of that wheel. Not an easy task, and not worth it for the wheel mfr to do that on a single order.
With a modular 3pc wheel, you can simply select a narrower outer lip section, which allows the hub section of the wheel to be much thicker given the same offset, giving you the clearance you need. Nothing really needs redesigning, it's just a matter of how much material is milled off the backside of the hub of the center section.
Most all custom modular wheel mfr's have measurement charts you can fill out for custom applications, and the caliper clearance is a big part of that. If your brakes don't clear the stock wheels, you are definitely going to need custom 3pc wheels.
