Best X pipe...
Old Jun 4, 2005 | 02:11 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
Default Best X pipe...
What do you think is the best X pipe to compliment my Borlas and stock headers? I assume this is a DIY install, much like the Borlas? Thanks guys!
Old Jun 4, 2005 | 02:37 AM
DsC5's Avatar
DsC5
I don't think there is a "best" per se, so long as it is stainless from one of the usual names, you'll be fine. Except for the cutting aspect, it is a DIY install.
Old Jun 4, 2005 | 03:08 AM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Thanks for the reply. I thought I had heard others were "better" than others, but that's been a while.
So what exactly needs to be cut?
Old Jun 4, 2005 | 03:29 AM
DsC5's Avatar
DsC5
You'll need to cut a few inches behind the cats, the X-pipe slips over the stock pipes on the front end, and bolts up to the flanges at the rear.
Old Jun 4, 2005 | 06:50 AM
Dark-Knight's Avatar
Dark-Knight
Bill, you may want to consider replacing the entire center section and include some high-flow cats with your mod. No cutting and even a better flow. I've got Random tech center with slip flanges, easy to deal with, high flow and very clean looking.
Hope you find what you're looking for! Cya!
Old Jun 4, 2005 | 07:38 AM
I have a Bassani X-pipe on mine - does the job I bought it for - quiet the drone and resonance in the car. Had to cut the stock exhaust behind the cats to install, which I left to a local muffler shop. Cost was $30 for them to cut and install.
Old Jun 4, 2005 | 08:21 AM
not08crmanymore's Avatar
not08crmanymore
Default x-pipe
if you want some real benefit,get the kooks headers w/hi-flow cats and a 3 inch x-pipe.otherwise the rest are pretty much all the same...corsa,borla whatever.i was amazed at the difference in my corsa when it came off and was up next to the 3 incher from kooks.borla makes a pipe,so if you don't go the header route,you may as well keep everything borla.no welding,cutting that i know of or ever had done.
Old Jun 4, 2005 | 08:31 AM
Tino's Avatar
Tino
Does the x-pipe replace the h-pipe in the exact same location on the stock system.
Tino
Old Jun 4, 2005 | 09:31 AM
01VETTECOP's Avatar
01VETTECOP
I have a Magnaflow. I chose it because it is one solid piece of SSteel and it is a nice piece (Meaning construction and quality)
Old Jun 4, 2005 | 09:36 AM
jrose7004's Avatar
jrose7004
Call me old fashioned but what ever cat back system I would have would be the kind of X-Pipe I would get!
Old Jun 4, 2005 | 10:22 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
It might make alignment of the tail pipes a lot easier too.
Tom
Old Jun 4, 2005 | 06:47 PM
Z0SLIK's Avatar
Z0SLIK
Old Jun 4, 2005 | 08:04 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Tino
Tino, I don't know about exact but it's pretty darn close. There are no fitment issues if that's why you ask.
Old Jun 4, 2005 | 08:06 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Best what? Price, ease of installation, silencing of the burble, most precise welds? What?
Old Jun 5, 2005 | 05:31 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
I should have clarified. I'm looking to gain the most from the sound, really. I was just wondering if my Borlas would sound even "better" with an X-pipe. By better I mean less burble and even a deeper sound. Thanks all!
Old Jun 5, 2005 | 10:11 PM
2000droptop's Avatar
2000droptop
St. Jude Donor '07
My Corsa's sound better with the X-pipe.
To Best X pipe...
