Anyone Use Langka?
Old Jun 4, 2005 | 06:21 AM
JLA's Avatar
JLA
Default Anyone Use Langka?
http://www.langka.com/
I've never been any good at touching up paint. It always looks worse than when I started. Anyone have success with this?
Old Jun 4, 2005 | 06:42 AM
OkeeGuy's Avatar
OkeeGuy
Old Jun 4, 2005 | 06:47 AM
BT-01-vette's Avatar
BT-01-vette
From what I've read about people using it in the past, it's supposed to be the best product available and not hard to use. I plan to give it a try in the near future since an huge rock put a nice chip in my hood last summer.
Old Jun 4, 2005 | 08:49 AM
indy300's Avatar
indy300
I've used it. I works pretty good. It definitely removes the paint blob.
Old Jun 4, 2005 | 09:11 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
It does take a couple practice tries to get a perfect repair. But, the best part is; if you remove too much of the blob you just add a little more paint and start the process over. No harm done.
Old Jun 4, 2005 | 09:56 AM
silverhead's Avatar
silverhead
I have used this product and it works great.
It does take trial/error at first, but once you get the "hang" of it, the touch up blends right in.
Good luck.
Old Jun 4, 2005 | 10:00 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Looks like a great product. I've got a couple of small scratches I wouldn't mind trying this out on. Thanks for posting.
Old Jun 4, 2005 | 10:16 AM
o_town_racer's Avatar
o_town_racer
I have found that it works better for solid colors....less so for metal flakes. The problem is that it removes the excess paint, but the flakes remain and the color of the paint changes (gets darker, flat not shiny).
Old Jun 4, 2005 | 05:29 PM
BadBone's Avatar
BadBone
It's a good product, it works as advertised. My only problem has been the touch up paint that I bought from a vender at Carlisle, the paint is so thin that I can't get it to over fill the chip without running down the hood. I need to buy some GM Lemans Blue touch up paint.
Old Jun 4, 2005 | 07:20 PM
gpotski's Avatar
gpotski
I have it at home, but am waiting to fill some paint chips until back from a 1000 mile trip to DC in a couple weeks.
Old Jun 4, 2005 | 07:40 PM
JLA's Avatar
JLA
I'm just outside of D.C. You'll need more than touch-up paint heading there. I wonder if Langka has the Bullet Hole Repair System? It might be a regional thing.
OkeeGuy's Avatar
OkeeGuy
i plan on buying some of this and trying it out...
i wonder how well it would work on my 25 yr old C3...?
acrylic enamel with no clear...
wheres a good place to get it from?
the only place i was able to find it on line was here...
http://www.premiumautocare.com/langka-pcrkit.html
Old Jun 5, 2005 | 01:30 AM
vizette's Avatar
vizette
Default clear coat
Do you guys clear coat after doing it? or mix clear coat with the touch up paint? or just Lanka it and wax/zaino?
-Rich
Old Jun 5, 2005 | 02:57 AM
TooTall's Avatar
TooTall
I have used it since I got my vert. Great Product! As said before it takes some practice but once you've developed the touch, you can make repairs that are almost invisible.
My tips:
1. Use a slower and lighter touch as you start to even out the bubble.
2. Patience!
3. Keep up on the touch up work (doing 20 at time is no fun and it leads to not following tip 1 and 2).
Good Luck,
TooTall
Old Jun 5, 2005 | 07:09 AM
Z0SLIK's Avatar
Z0SLIK
My tips:
2. Patience!
Good Luck,
TooTall
Thanks for the info!!
Old Jun 5, 2005 | 08:28 AM
indy300's Avatar
indy300
I agree with you 100%! I have a navy blue metallic and couldn't get the perfect color match and smooth blend. I ended up just trying cover the white chips with blue paint without having a blob. Good enough.
Old Jun 5, 2005 | 11:19 AM
DavesC5's Avatar
DavesC5
The key to to it is to not rush the job. Let the paint get real dry before you try to remove the excess. Even letting it dry a few days won't hurt.
To Anyone Use Langka?
Old Jun 5, 2005 | 11:31 AM
Postergeist's Avatar
Postergeist
Well I must be an idiot, because I didn't get the greatest results from it - I must not've followed directions well.
Tip: Use clear fingernail polish as a clearcoat. Nail polish the same color as your paint (and, believe me, you can find almost any color of our cars...except maybe yellow) makes a pretty good touch up of chips.
Old Jun 5, 2005 | 12:51 PM
Blue Lion's Avatar
Blue Lion
I've never used it, but based on what I've read previously I would try it.
Old Jun 5, 2005 | 03:21 PM
indy300's Avatar
indy300
A few days, huh? How long do you have to rub to remove the blob after that? I had to rub for a couple of minutes after letting it try for 45 minutes.
