[Z06] Heat Shields
Old Jun 4, 2005 | 01:51 PM
hocheehoba's Avatar
hocheehoba
Default Heat Shields
I put a Hurst shifter in place of the stock shifter. It seems there is more heat and an @$$ TON more sound coming up from under the stick shift boot. Is there a heat shield that be placed under the console to help prevent heat and sound?
Old Jun 4, 2005 | 03:56 PM
brian ns04's Avatar
brian ns04
Do a search and you will find the shields that will help with the handling of your car that also help with the heat. You can also do a search on Hurst shifters there are a couple of mods that you can do to cut out all the noise.
