How important are run flats REALLY?
Old Jun 5, 2005 | 06:33 AM
KeyoRacing's Avatar
KeyoRacing
Default How important are run flats REALLY?
I see that people seem to not like GF Run flats very much because of the noise that happens as they get older. I've never had them on my 2 other vettes because they were older and weren't offered. All that being said are they worth dealing with even with the extra noise?
Old Jun 5, 2005 | 06:45 AM
JLA's Avatar
JLA
No spare in the car. I'll put up w/ a little noise because of that alone!
Old Jun 5, 2005 | 06:49 AM
Z0SLIK's Avatar
Z0SLIK
I agree!!
Old Jun 5, 2005 | 06:50 AM
KeyoRacing's Avatar
KeyoRacing
damn it...I forgot about that.... you're right
Old Jun 5, 2005 | 06:51 AM
KeyoRacing's Avatar
KeyoRacing
So the best Idea is just to find a tire thats not a GF if it's that bad.
Old Jun 5, 2005 | 07:30 AM
csexton's Avatar
csexton
Lots of info on this forum about different brands of run-flats. Also check out Tire Rack, one of the forum vendors. They have a good info page about these tires.
Old Jun 5, 2005 | 07:35 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Run Flats-----Don't leave home with out 'em.
Old Jun 5, 2005 | 07:56 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
And you will lose another couple of inches in ground clearance with a flat making it difficult/impossible to get a jack and puck underneath and probably impossible to get onto a flatbed. As long as you have a slow leak to pump the tire back up to raise the ground clearance you'll be OK, otherwise you are in trouble, especially if your car is lowered.
Old Jun 5, 2005 | 07:59 AM
love my car's Avatar
love my car
i like mine.Its going to be intresting when i have to by tires.but i think ill get them again.
Old Jun 5, 2005 | 08:02 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
I never treat my tires as GirlFriends!
Old Jun 5, 2005 | 08:27 AM
Lancer033's Avatar
Lancer033
I say ditch the runflats
went through the Goodyears and a set of Yokohamas before I switched to Kumho MX non-runflats.
1. less noise
2. more traction
3. much less expensive (~$650 vs. $1000+ from tire rack for stock sizes)
I just keep a can of fix-a-flat in the car to deal with flats, but in the last 8 years, I've never had a flat (knock on wood).
Old Jun 5, 2005 | 08:29 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
1. less noise
2. more traction
You do know that fix-a-flat will screw up your pressure sensors, don't you?
Old Jun 5, 2005 | 08:44 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Screw the run flats. I carry a plug repair kit and a small compresor.
The one time I did have a nail in the tire. The first tire shop I went to (Sat afternoon). First thing they said (they saw me drive up) was no one there could pull a runflat off. Come back on Monday. Lucky for me, I did not have runcraps on the car. Fixed and out of there in 30 min.
And no, there tire never went flat, only down to 18 psi.
Old Jun 5, 2005 | 08:51 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I will always run some kind of run flat. Without a jack in the trunk it gives me peace of mind.
Old Jun 5, 2005 | 08:58 AM
Mike94ZLT1's Avatar
Mike94ZLT1
HOLY HELL I've never priced tires for these cars! I'm going to have to sell a kidney or something when I need tires!
Old Jun 5, 2005 | 09:25 AM
army2000's Avatar
army2000
St. Jude Donor '11
Yup, that "goop" fix a flat stuff will ruin a TPS. You have to use a plug it kit and AAA. The plug it kit only lasts long enough to get your vehicle to a repair shop.
Old Jun 5, 2005 | 09:33 AM
JWB ZO6's Avatar
JWB ZO6
I wouldn't put fix a flat in tire I use plugs and pump. Cell phone most important thing to have in car.
To How important are run flats REALLY?
Old Jun 5, 2005 | 09:38 AM
3318C5's Avatar
3318C5
I got rid of the run flats. We should not have to suffer with stiff/noisy/ tires because GM decided not to fit our cars with a spare tire. I got rid of them and put together a kit. A compressor, plug kit, small jack, and a ratchet(wheel removal). All this fits nicely in the storage compartments.
Old Jun 5, 2005 | 09:41 AM
Mike94ZLT1's Avatar
Mike94ZLT1
I read somewhere about a GTO spare tire fitting our cars, and being very low profile. That might be worthwhile...
Old Jun 5, 2005 | 11:42 AM
Postergeist's Avatar
Postergeist
I've had 2 C5's and switched to non-runflats on both. Never any concern whatsoever of a flat tire. I've never in my life had one on any car (watch: I'll get one now). The cost of runflats helped sway my decision to get away from them.
