Ok here's the story. Washed the car but didn't get the engine wet. Went to start her up for a cruise and the engine is loping..........like there isn't getting enough fuel???? It doesn't stall out but it drives rough. I thought it was bad gas but I did run it for 25 miles and that didn't help at all. So what do you all think the problem is. Also it isn't throwing any codes or any light on the dash????? Please give me some idea's.......thanks
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Mine used to miss at high RPM after a wash before I got the hood seal. My advice would be to take the filter off and let it dry or blow it out with an air gun. Don't know if this is the problem, but that happened with mine and thats what I did. Good luck,
Thanks guys...........CCMC5 got the juices rolling as I did screw with the black wing....the air intake was dislodged tightned it back up and good as new....alohhaaaaaaaaaaaaa
Cool, I'm glad that was the problem and nothing MAJOR!!!
