Clicking sound from tire
Old Jun 5, 2005 | 11:31 PM
DAC350's Avatar
DAC350
Default Clicking sound from tire
When I am driving slow I hear a repetitive clicking sound from the front left tire. It's also a little louder when I turn left. What could be causing this? I did check for nails/rocks in the tire and found nothing. Thanks.
2000 A4 coupe
Old Jun 6, 2005 | 12:17 AM
Red Rag Top's Avatar
Red Rag Top
Could be a wheel bearing.
Old Jun 6, 2005 | 01:00 AM
SPD KILZ's Avatar
SPD KILZ
what kind of wheels are you running?
Old Jun 6, 2005 | 01:02 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Just a possible easy thing to check....you haven't had any of your brake shims slip out around the brake caliper hitting your wheel have you?
Good luck figuring it out
Chris
Old Jun 6, 2005 | 08:49 AM
DAC350's Avatar
DAC350
i will check the shim, I just bought the car so I'm still spending my time driving it and having fun! It has the stock 2000+ polished wheels. Thanks.
Old Jun 6, 2005 | 08:52 AM
C5 4 ME's Avatar
C5 4 ME
I would check out the brakes.
Old Jun 6, 2005 | 09:07 AM
DAC350's Avatar
DAC350
What should I look for with the brakes? Just the shim? I changed pads on my 94 TA many times, these look similar...just 2 piston right? What else brake related would it be other than a shim that would click? Thanks.
Old Jun 6, 2005 | 01:07 PM
bierbelly's Avatar
bierbelly
I had a similar problem last week, but it turned out to be a stone in the tread.
Old Jun 6, 2005 | 08:29 PM
SPD KILZ's Avatar
SPD KILZ
I dont know about stock wheels but, iv had the tabs on the center (chrome z06 replicas) caps break off and rattle around inside the cap. It drove me nutz till I finally had the entire wheel off bouncing it in anger only hearing the noise again.
Old Jun 7, 2005 | 12:26 AM
George8211's Avatar
George8211
R O C K
Old Jun 7, 2005 | 08:12 AM
Kris072's Avatar
Kris072
My center caps did that to me too. Drove me nuts. I went and got some shrink tubing the same size as the tab, and voila... allllll gone !
Old Jun 7, 2005 | 09:01 AM
Red Gump's Avatar
Red Gump
had this happen to me once--turned out to be weight tape! simple! check your weights, if they're stick on then it's something else but if they're stick + tape, the edge of the tape may catch the caliper.
Old Jun 7, 2005 | 09:32 AM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I had the weight tape problem as well. Good luck in finding the problem.
Old Jun 7, 2005 | 11:41 AM
torchredfrc's Avatar
torchredfrc
Check your center caps. Mine were a very loose fit, I used some high temp weather stripping on the edges of the caps to get them to fit better. No more rattle.
Old Jun 7, 2005 | 11:57 AM
pewterwest99's Avatar
pewterwest99
This thread could not have come at a better time!!! Mine just started to do this
Old Jun 7, 2005 | 07:56 PM
DAC350's Avatar
DAC350
Well, after further inspection it's the rear drivers side tire. I haven't taken it off yet but have more info on the "click" If I just sit and switch between drive and reverse and barely move the car, I hear the click. I move maybe 3 inches after switching into to gear and I hear 1-2 clicks. If I roll it clicks a lot at slow speeds randomly. It does this with the brakes engaged and not engaged. Any other ideas for me to look at? Thanks.
Old Jun 7, 2005 | 08:05 PM
Kris072's Avatar
Kris072
Take your center cap off and re-test. That will at least confirm or eliminate that possibility
To Clicking sound from tire
Old Jun 7, 2005 | 08:09 PM
George8211's Avatar
George8211
Make sure your lugs are torqued properly.
Old Jun 7, 2005 | 09:59 PM
gpotski's Avatar
gpotski
Might also be the endlinks on the sway bars. Check that they are torqued well.
Old Jun 7, 2005 | 10:02 PM
DAC350's Avatar
DAC350
OK, just took off the center cap and torqued the lugs. Still makes the sound. I slightly loosened the lugs just to test and it still clicked/popped. I actually can make it click without even starting the car, if I just rock the car back and forth slightly it will make the sound. It sounds like it is coming from the outside area around the rim, not anything deeper like the differential. Upon rocking the car I can also hear the rear passenger tire making the same popping noise, just not as loud as the driver side. Any thoughts? Repetitively pops when putting into gear, and when traveling slow. Thanks.
