Problem with cargo bay cover
Old Jun 6, 2005 | 12:48 PM
SavPrato's Avatar
SavPrato
Default Problem with cargo bay cover
I had a wierd experience with the cargo bay cover on my 03 coupe the other day. I managed to close the hatch with a portion of the cover flap stuck in the driver side latch. The hatch release would not work because of this and I had to force the hatch open from the inside. What a pain!!! Is it just me or is this problematic if you're not careful closing the hatch?
Old Jun 6, 2005 | 01:00 PM
Ghost Vette's Avatar
Ghost Vette
I don't see how the cover even gets close to the latch. The cargo bay ring should be in the catch on the hatch. The only way I see this could happen is if you put on backwards with the flap hanging down at the rear instead of in the front.
Old Jun 6, 2005 | 01:25 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Old Jun 6, 2005 | 02:47 PM
PEW01's Avatar
PEW01
Old Jun 6, 2005 | 04:51 PM
SavPrato's Avatar
SavPrato
DOH !!! Then I guess that I've installed it backwards as the flap is at the back. Guess I'd better turn it around.
Old Jun 6, 2005 | 05:15 PM
That's the only way I could see this happening.
To Problem with cargo bay cover
