Hey all,
I have the stock tires and rims all around, but recently purchased a set of 17" wheels with nitto DR's for use at the track....Is it ok to drive the car with the same diameter 17" wheels and tires on all 4 corners, or will this mess with the active handling as some people claim?
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
IMHO, don't think they'd look that hot. Post some pics of them next to the car and maybe you'll get some more feedback. As for them causing problems, I know that people go with larger sizes so I don't see why smaller would hurt, but I could be wrong.
hi,
if im feeling lazy after a track event, i'll leave mine on. no issues. other than the pesky DIC message about tire pressure sensors. i dont have sensors with my et street radials (track tires). just have to clear/reset it once the car starts..then normal after that...17's all around.
My understanding from reading a lot of the "lowering" posts and other tire posts is that active handling must have a front to back offset of about 1" to be "happy". You could do that with 17's by altering the tire diameter from front to back.
Most of the T-1 and SCCA racers use 17s all around. Active handling, I have been told, is mostly about electronic adjustment of your shock stiffness. Don't worry about it. Or, dump the heavy and 'expensive to replace' electric shocks [ pun intended] and buy a set of Bilstein Sports. ...reliable and always working. I REALLY like mine.
I am now running 17 and 18, but same 9.5 inch wide front and back, for wider front tires to help reduce inherant understeer in stock tire sizes..... wheels by Speedline of Italy.
The system that would affect shock stiffness is Selective Ride Control. Active Handling is a completely different system.
The Active Handling controller takes data on wheel speeds, steering angle and rate, yaw rate, lateral acceleration and brake pressure. If it detects a significant understeer situation, it will momentarily apply or, if the driver is already on the brakes, increase pressure to the inside rear brake. That applies additional yaw torque to the car in the direction it is turning which decreases the understeer. If the controller detects an excessive oversteer situation, Active Handling applies the outside front brake. This time, the yaw torque is opposite the turning direction and decreases oversteer.
The system is calibrated for the 1" difference in diameter between the front and back wheels, which is why it can cause issues when running the same tire diameters. I would venture to say that those folks running 17's all around still have staggered tire diameters.
Thanks for all the information guys, it really is a wealth of knowledge here...The reason I ask is that I am planning on running the stock front tires with a set of 275/40R17 Nitto DR's on the rears whenever I go to the track (also includes the trip to and from the track)...Do I have to turn active handling off whenever running this combination since they are pretty much the exact same diameter tire?
The active handling issues aside and from a purely aesthetic perspective, you're going to have trouble filling your wheel well to the same degree it's filled on the front. Just keep that in mind. I know - I've been there.
