front turn signal
If you can, get the front end of the car ramped.
Remove a couple of bolt/screws and remove the side of the airdam you want to access.
From there, you can easily turn/pull the bulb socket. Pull the bulb and reverse to reinstall.
OOOOOOR:
Open the headlights, then back one click (leaving the parking lights on and headlight covers up)
Remove the bezel around the headlight.
If your arm (or the arm of a petite individual) , reach into the nose and turn/pull the bulb socket.
can somebody please tell me how to access front turn signal bulb for replacement.dealer has enough of my money.there has got a be a link
