Tail Light
Jun 7, 2005 | 11:38 AM
4th Gear
Tail Light
I need help repacing a rear tail light bulb????
Can somebody please help me!!!!
Jun 7, 2005 | 11:42 AM
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
you need a t15 torx driver - remove the two screws and pull out the housing - bulb is accessible from back side, pretty straight forward.
Jun 7, 2005 | 11:44 AM
I believe you can just unscrew the two screws holding in the cover. Then you should be able replace the bulb
Looks like I was a little slow. Well , best of luck
Jun 7, 2005 | 11:46 AM
4th Gear
Brake Lights
By the way is it done the same way for one of the four brake lights???
Jun 7, 2005 | 11:56 AM
St. Jude Donor '05, '12-'13, '15-'16, '21
Quote:
Originally Posted by tuf2tame
Identify which bulb is burned out, remove the lens, pop out the housing and replace the bulb.
Jun 7, 2005 | 12:16 PM
Quote:
Rightee tightee, leftee loosey....
Jun 7, 2005 | 12:21 PM
CI 5-6-7-8 Veteran
NCM Ambassador
There is a single, dual filiment bulb behind each of the four taillights.
Jun 7, 2005 | 01:03 PM
You need a torx bit to loosen the two screws in the tail light assembly, then just pull the light out. Then just remove the socket and put in a new bulb. Install is the reverse.
