[Z06] Fred Beans June C5 Specials!
Old Jun 7, 2005 | 06:57 PM
Gene@FredBeans's Avatar
Gene@FredBeans
Default Fred Beans June C5 Specials!
Hello All,
In June, we are doing the 5% over dealer cost special again. If you are interested in something else other than what's listed here please contact myself or Jeremy directly. We advertise on a lot of boards and don't have a lot of time during the day to visit them. This will also increase your response time. Please give us a call @ 610.495.1700 or send me an email to gculley@fredbeans.com
Thanks!
Gene
||--Genuine GM C6 Shifter Kit--||
15232012 – C6 shifter
10354701 – C6 shift ****
11609670 - Bolt
Both parts 190.39 + 18.50 shipping
||--Genuine GM Engines--||
12498399 – 2002 + LS6 engine – 5030.13 (dealer cost)
12480030 – GM Performance Parts C5R block – 6350.00
89017654 – LS2 engine – 5299.23 (dealer cost)
12568950 – LS2 bare block – 906.50 + 90.00 shipping (dealer cost)
12572808 – 6.0 cast iron bare block – 620.56 + 90.00 shipping (dealer cost)
Please ask us about the engine shipping costs directly!
||--Genuine GM Z06 Items--||
Z06 calipers – 322.12 + 15.50 shipping
Z06 front screens – 90.80 + 12.50 shipping
Z06 front brake ducts – 10295976, 10295977 – 16.29 each + 9.45 shipping
Z06 rear screens (scoops) – 10322761, 10322762 – 55.91 each + 12.50 shipping
Z06 rear brake ducts – 10425977, 10425976 – 16.01 each + 8.60 shipping
Z06 2004 shocks – 335.48 + 23.50 shipping
Z06 sway bar kit – 216.75 + 28.95 shipping
Z06 sway bar kit (insulators and bars only, no end links) – 152.39 + 26.50 shipping
Z06 front brake pads – 88952008 – 106.53
Z06 rear brake pads – 12530688 – 49.84 – shipping for front and rear is 14.50
Z06 rear differential assembly – 12572683 – 925.09 + 90.00 shipping (dealer cost)
Z06 front suspension spring – 22178729 – 382.13 + 28.50 shipping
Z06 rear suspension spring – 22188038 – 382.13 + 28.50 shipping
||--Genuine GM HUD Setup--||
10279814 – HUD - 175.00
12198648 – Switch - 66.10
10425223 – Bezel – 17.14
Shipping for the HUD setup is 18.50
||--Genuine GM Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 54.77 each
15125473 - nuts – 2.45 each
Total setup is 228.88 + 15.50 shipping
97-2000 Sensors
10438853 - sensor – 84.40 each
10268439 - nut – 1.25 each (5 pack)
10268438 - washer – 1.25 each (5 pack)
Total setup is 350.10 + 15.50 shipping
||--Genuine GM Corvette Clutch Parts--||
89059282 - LS6 Slave Cylinder – 92.75
12564455 - LS6 Master Cylinder – 94.61
12570806 - LS6 Clutch Kit – 343.17
14061685 – LS1/LS6 Pilot Bearing – 8.75
Shipping for clutch is 45.00. The clutch + any other components is 55.00 shipping
||--Genuine GM LS2 Items--||
89017648 – LS2 intake manifold – 227.73 + flat fee of 5.00 shipping (dealer cost)
12570790 – LS2 throttle body – 224.91
12572174 – LS2 fuel rails – 101.35
89017587 – LS2 injector o-rings – 19.17
||--Genuine GM LS6 Intake Manifold--
88894339 - Intake Manifold Only - 408.92!!
88894339 - Intake Manifold W/Coolant Pipes And Plugs - 449.28 shipped
||--Genuine GM UltraGuard UPF 44 Oil Filters--
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ 46.25 shipped!!
||--Genuine GM Cylinder Head Bolts And Gasket Kits--||
12498543 - 97-01 LS1 Engine Head Gaskets (2) – 31.96
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) – 22.77
12498545 - 97-12/03 LS1 & LS6 Engine Head Bolts – 15.48 per head
17800568 – 01/04 – present LS1/LS6/LS2 Head Bolts – 14.95 per head
If you’re not sure which bolt kit to use please email us your VIN# and we’ll tell you!
||--Genuine GM Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 104.74 + 14.50 shipping
||--Genuine GM Brake Rotors--||
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
Front and rear rotor sets 222.06 + 35.50 shipping
AC Delco Performance Drilled/Slotted
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Front and rear rotor sets 170.26 + 42.73 shipping
||--Genuine GM T1 Engine/Suspension Items--||
T1 shocks – 556.96 + 28.50 shipping
T1 trans cooler – 835.89 + 28.50 shipping
T1 sway bar pkg with insulators and end links – 596.49 + 55.00 shipping
T1 complete suspension package – 2434.97 + 75.00 shipping (dealer cost)
T1 suspension springs 663.02 each + 28.50 shipping each (dealer cost)
||--Genuine GM Engine Parts--||
12564824 - '02 LS6 Cylinder Head (Assembly) – 695.00 (dealer cost)
12564825 - '02 LS6 Cylinder Head (Bare) – 613.07 (dealer cost)
12480110 - ASA Racing Cam - 358.79
12480033 - LS1 Hotcam Kit - 430.61
88958622 - LS6 CNC Ported Cylinder Head (Assembly) - 940.50each!! (dealer cost)
||--Helms Service Manuals--||
'97'- '04 Corvette - 124.95 shipped!!
Please Call For Any Other Make/Model Vehicle!
||--Genuine GM LS1/LS6 Fuel Rail Covers--||
12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering)
12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering)
Both FRC’s 46.60 + 12.50 shipping
12561503 - '99-'02 LH Fuel Rail Cover (Black with Red "Corvette" Lettering)
12561502 - '99-'02 RH Fuel Rail Cover (Black with Red "Corvette" Lettering)
Both FRC’s 55.62 + 12.50 shipping
12564257 - '01-'02 LH Fuel Rail Cover (Red With Black "Corvette" Lettering)
12564258 - '01-'02 RH Fuel Rail Cover (Red With Black "Corvette" Lettering)
Both FRC’s 82.22 + 12.50 shipping
Fred Beans Pontiac Buick GMC Terms And Conditions Of All Sales:
We reserve the right to change the price of any part at any time and/or refuse to sell a part for any reason at any time. Price changes that can be made through the month are final and all sales before and after the price change are final. We will accept no returns after 30 days and all boxes or packages must be in the same condition as which they were received. If a package is received in anything other than perfect manner, please call and note upon receipt. Anything noted after the fact is the responsibility of the buyer. All returns are subject to a 20% restocking fee and/or a fee for unacceptable boxing or packaging. We reserve the right to change the terms and conditions of a sale at any time for any reason.
Old Jun 12, 2005 | 11:30 AM
Gene@FredBeans
Give us a call or email guys!
Thanks.
Gene
Old Jun 14, 2005 | 10:44 PM
Gene@FredBeans
Give us a call!
Gene
Old Jun 16, 2005 | 12:08 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Gene when will you be getting the LS7 crate motors in stock & do you have any pricing info that you can share with us yet?
Old Jun 16, 2005 | 07:23 PM
Gene@FredBeans
I will get one as soon as they release them. Pricing has not been released yet, I check every morning.
Gene
Old Jun 19, 2005 | 11:08 AM
Gene@FredBeans
Thanks.
Gene
Old Jun 22, 2005 | 07:33 PM
Gene@FredBeans
Hello All,
I have a C5R block that just arrived. It is 6350 plus shipping. Give me a call or email!
Thanks.
Gene
Old Jun 27, 2005 | 07:09 PM
Gene@FredBeans
Gene
Old Jun 29, 2005 | 07:14 PM
Gene@FredBeans
Give us a call tomorrow guys. Tomorrow is the last day of the June specials.
Thanks.
Gene
Old Jun 29, 2005 | 08:42 PM
kedvesh's Avatar
kedvesh
Thanks for continuing to offer the specials!
The Z06 engine looks tempting.
Old Jun 30, 2005 | 01:12 AM
Pio's Avatar
Pio
Will the C6 shifter fit the C5? I love that shifter!
Old Jul 4, 2005 | 08:54 AM
Gene@FredBeans
It sure does. That is one of the reasons I included it in the C5 specials!!
Happy Independence Day All.
We will be selling the LS7 for 12,595. If you're seriously interested please let me know and we'll proceed from there.
Gene
To Fred Beans June C5 Specials!
