Shifter Question?
Old Jun 10, 2005 | 01:19 PM
99vertnbm's Avatar
99vertnbm
Default Shifter Question?
Brand new member-long time reader
I hava a 99M6, I could twist shift ****, so I thought. Today I pulled up on shifter and the shift lever came right out of shifter and boot. I just stuck it right back in. Works. Is this normal with stock shifter? Thanks in advance.
Old Jun 10, 2005 | 01:26 PM
binkysgarage's Avatar
binkysgarage
Doesn't seem right, did the ball come off or the stick, the factory shift **** is pinded in place and should not turn, unless its been changed. I've never heard of a stick coming out its a bolted assembly to the trans.
Old Jun 10, 2005 | 01:30 PM
99vertnbm's Avatar
99vertnbm
The whole stick just came out. I wouldn't come out of the boot, I guess because of the ball.
Old Jun 10, 2005 | 01:32 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Sound like it's time to buy a Hurst, cuz yours is SHOT!! NO WAY it should do that!!
Old Jun 10, 2005 | 01:34 PM
binkysgarage
Something is not right under that boot, you need to pull the boot up and check it out. Maybe the shifter came apart.
Patches's Avatar
Patches
Sounds like your upper shifter shaft assembly with the rubber isolator in the center came loose from the lower shaft. You need to fix this or replace it or it may come loose again when you least expect - or want - it to. You may want to look at replacing it with the revised C6 sshifter or one of the aftermarket shifters such as the Kirban, Ripper or Hurst.
Old Jun 10, 2005 | 01:37 PM
99vertnbm's Avatar
99vertnbm
Thanks guys. I was away from home when it happened. My heart sank thinking I was gonna be stranded but it went back in and works.
Also tell me how you wait for a reply without going back and then refreshing page. I new remember.
WaWaTuSi's Avatar
WaWaTuSi
St. Jude Donor '05
Good excuse to get a Husrt!
Old Jun 10, 2005 | 05:53 PM
rickko's Avatar
rickko
You can "Subcribe" to the thread w/Instant Email Notificationl option selected, then wait for your email program to tell you its received a reply to your thread, else you MUST refresh if you remain logged into the forum.
Good luck!
..rickko..
To Shifter Question?
