Whats the differnce between a 98 and 04 c5
Old Jun 11, 2005 | 01:56 AM
c4vetteontop's Avatar
c4vetteontop
Default Whats the differnce between a 98 and 04 c5
Whats the differnce between the 1998 c5 coupes and the 2004 c5 coupes. IS there something differnt with the engine and can you tell from the outside. (or inside the car)
Old Jun 11, 2005 | 02:03 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
'98 has a keyhole on the passenger door, '04 doesn't.
'98 has no HUD, '04 does.
'98 has wagon wheels, '04 has thin spoke wheels
'98 has plain exhaust pipes, '04 has chrome tipped pipes.
'98 has 2 fuel lines (or something like that) into the engine, '04 has 1
Then there are the dozens of changes and improvements under the hood and elsewhere.
Old Jun 11, 2005 | 02:10 AM
vette_fiend's Avatar
vette_fiend
From the outside, the only noticable differences would be the lack of a passenger side door lock on the '04, as well as the wheels. On the inside, the '98 didn't have the HUD or the electrochromatic mirror. As far as the engine goes, the '04 would have different injectors and MAF. I also believe that after 2000, all the C5's got the LS6 intake and block, someone can correct me if I'm wrong. Later '04 models also picked up fuel system parts from the C6.
Old Jun 11, 2005 | 03:17 AM
ronniej's Avatar
ronniej
St. Jude Donor '06
Here's the info you're after:
http://www.eliteengineeringusa.com/C..._in_models.pdf
Old Jun 11, 2005 | 06:34 AM
SlideRulz's Avatar
SlideRulz
Originally Posted by ronniej
Thanks for the info
Old Jun 11, 2005 | 07:59 AM
gredmer's Avatar
gredmer
About 6 years.
Gillespie's Avatar
Gillespie
dang, beat me to it gredmer.
Last edited by Gillespie; Jun 11, 2005 at 08:04 AM. Reason: beat to the joke by gredmer
Old Jun 11, 2005 | 08:12 AM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
I don't think that is right. My 2000 does not have the passenger airbag switch or light.
Old Jun 12, 2005 | 09:16 PM
ronniej's Avatar
ronniej
St. Jude Donor '06
My 2000 does. I believe the later model 2000's have it.
Old Jun 12, 2005 | 09:24 PM
chriswtx's Avatar
chriswtx
:. Miscellaneous .:
All of this information is variously collected from the Corvette Forum message board, so do not take it as absolute gospel. However, it should be somewhat close. Sources: 1,
1997
Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
All Z51 cars include: Power Steering Cooler, xx, xx, ??
97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
Convertible becomes available
Active Handling becomes available late in year
The two slots of a 1998 (and possibly late 1997s) curve toward the rear at the bottom. (versus straight down)
1999
26# injectors substituted for 28#
Fuel pump revised to reduce noise
FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
HUD introduced
only one line in driver's side fuel rail cover (no fuel return line?)
Power telescoping wheel becomes an option
? Steering hardware changed to combat wandering
door sill trim plates added
2000
Millennium Yellow available
? "Thin Spoke" versus "wagon wheel" design wheels become standard.
Pup cats added to CA models for LEV emissions requirements (5hp loss relative to 97-99)
Steel swaybar endlinks instead of plastic on Z51 equipped cars
Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
No keyhole on passenger side doorhandle
Passenger airbag 'off' switch added to console (light by TC/AH button)
2001
return to 28# injectors for all models.
Second Generation Active Handling
Nassau Blue discontinued
Alternator 'clutch' pulley added on A4 cars
New soundproofing + foam in all cars
Smaller keyfob
electrochromic dimming rearview and driver's mirrors
lighter AGM battery
Thickness + Material in vert change
Chrome exhaust tips for coupe + vert
85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
All Corvettes now have the LS6 intake manifold
All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
Hardtop/FRC discontinued
Pup cats added to all models
Stronger synchros in all transmissions
Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
metal valvestem caps (late year)
Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
Introduction of the Z06, which has as differences:
hardtop body style
rear brake ducting
screened inlets on front fascia, without foglights
F1 supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
new LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
Titanium exhaust system
lightweight windshield
New, stronger clutch with redesigned master + slave cylinder
Stronger rear differential (shotpeened ring gear)
Red brake calipers (otherwise identical)
Trans overtemp warning light on DIC
6500 redline gauges with special checkering + Z06 font
redesigned PCV system to help combat oil burning
Red LS6 Fuel Rail Covers (FRC's)
FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
Z06 Changes:
Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
Less restrictive intake airbox lid
Descreened MAF
Removal of pup-cats (total with changes = 405hp)
Z06 shocks revised with less rebound for better launching
Z06 brake pads revised for better stopping (generate more dust)
Lighter, sodium filled valves w/ stronger valvesprings
higher tension rings installed to prevent oil burning problems
slight piston redesign *
clutch strength upgraded.
HUD available on Z06 (not avail '01 model year)
Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
Electron Blue color offered
Steel endlinks changed to aluminum
2003
Late model-year new fuel system design from C6's
2004
· Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
Is this enough info...
Old Jun 12, 2005 | 11:15 PM
abigfoot's Avatar
abigfoot
about 18000.00
Old Jun 13, 2005 | 05:13 AM
FiberglassFan's Avatar
FiberglassFan
Also starting in 2000, the cars contain a memory device that records speed and multiple functions for a period of time. If you have a wreck, the Police and download the data a see how fast you were going, in fact an entire vehicle profile for several minutes before 'shutdown'. If your innocent, this can save your a$$ proving that you werent really doung 147MPH, if your guilty of excessive speed, it can hang you. Some owners of late year Vettes have actually removed the memory system.
Old Jun 13, 2005 | 02:09 PM
davee01's Avatar
davee01
2003 the Magnetic Ride became available....
As lots have said, buy the newest you can afford.....
To Whats the differnce between a 98 and 04 c5
