Greasing the splines
Old Jun 11, 2005 | 10:44 AM
DAC350's Avatar
DAC350
Default Greasing the splines
My back tires are clicking, and I was told that I need to grease the splines. How do I do that and what kind of lubrication do I use? Is it hard to do? Thanks.
Old Jun 11, 2005 | 11:23 PM
Nitro Junkie's Avatar
Nitro Junkie
Either pull the wheels, or remove the center caps. Remove the BIG nut. Spray white lithium grease all up into the splines. Reinstall the BIG nut. Torque it down (150 ft-lbs I think). Reinstall wheels or center caps.
Worked for me. I removed the wheels to clean them up and check the brake linings.
