Flat Tire
Old Jun 12, 2005 | 07:26 PM
Robert G's Avatar
Robert G
4th Gear
Default Flat Tire
Got a flat tire today. Found a screw in the middle of the tread resulting in a slow leak. It's not near the sidewall so I would guess it's repairable.
I've heard it's hard to find someone who will repair runflats. Can anyone recommend someone in North Central San Antonio who will do this without damageing the rim.
Thanks for your help.
Old Jun 12, 2005 | 07:30 PM
army2000's Avatar
army2000
St. Jude Donor '11
if you have EMT's it might be hard to find someone. Those run flats are a MF to work with and most tire shops already know about them. Goodyear might be your only hope. Good luck.
Old Jun 12, 2005 | 07:34 PM
army2000's Avatar
army2000
St. Jude Donor '11
http://www.tirerack.com/installer/index.jsp
Old Jun 12, 2005 | 07:39 PM
Robert G's Avatar
Robert G
4th Gear
Thanks for the info. There is a Goodyear store just down the road. The tires are the original Goodyear EMT's, but they only have around 6,000 miles on them.
Old Jun 12, 2005 | 07:58 PM
lynxshooter's Avatar
lynxshooter
good luck w/ goodyear. my goodyear repair shop won't even fix their own product, unless they installed the tires.
lynx
Old Jun 12, 2005 | 08:23 PM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
Find a friend in the tire business that you trust and that trusts you. Let them know that you will not hold them liable if the patch fails. I think you will be happy with the result (they are easier to patch than most realize).
Old Jun 12, 2005 | 08:38 PM
They should be able to repair the puncture, just be sure they use the plug and patch method. Goodyear may be able to do it for you, but be prepared - they sometimes charge an arm and a leg to work on the runflats.
Old Jun 12, 2005 | 08:40 PM
bierbelly's Avatar
bierbelly
My local NTB fixed mine, but it took them twice to get it right.
Old Jun 12, 2005 | 08:45 PM
mozart's Avatar
mozart
-I have had three flats on my emt's and all three times Discount tire fixed them at no charge and did and excellent job and took care when jacking , removing and re torqieing the wheel. If you have one in your area give them a try. The goodyear store woundn't touch them and said they didn't have the equipment to work on emt's ???
Old Jun 12, 2005 | 08:50 PM
TexasMadMan's Avatar
TexasMadMan
Plug & patch method? I always thought a patch was superior to a plug. Am I to now assume you need to do both? That doesn't sound right. Please explain.
Old Jun 12, 2005 | 08:51 PM
Dave1998's Avatar
Dave1998
my Goodyear dealer did it quickly but charged me $ 44.
Old Jun 12, 2005 | 09:41 PM
RCK1999's Avatar
RCK1999
Damn, and I ditched my run-flats!
Old Jun 12, 2005 | 09:42 PM
Wisdom's Avatar
Wisdom
I'll second the Discount Tire vote. They are a GREAT company to do business with.
- Wisdom
Old Jun 12, 2005 | 09:54 PM
mcronec5's Avatar
mcronec5
Cruise-In VII Veteran
Replace them with Kumho Ecsta ASX's.
Old Jun 12, 2005 | 10:24 PM
L iminator's Avatar
L iminator
Madman,I think they are referring to a type of patch that has built in plug. In the process of installing the patch the plug is also inserted in the hole. The thought being the two together are stronger and better seal than either is alone. I think this is correct as I had never heard of this either until my first EMT flat tire.
To Flat Tire
