Difference between 97-98
Old Jun 12, 2005 | 09:24 PM
turboedv6's Avatar
turboedv6
Default Difference between 97-98
Looking to buy a C5 Vette, I wanted to know what the difference between a 97 and a 98 C5 with a M6 tranny, performance, style, those things.
Old Jun 12, 2005 | 09:34 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
other than verts in 98, I think they only made minor tweaks..
Old Jun 12, 2005 | 09:37 PM
ronniej's Avatar
ronniej
St. Jude Donor '06
Here you go:
http://www.eliteengineeringusa.com/C..._in_models.pdf
Old Jun 12, 2005 | 09:44 PM
mcronec5's Avatar
mcronec5
Cruise-In VII Veteran
Ronniej, you are the man, I was going to chime in with the differences, but I think you covered it.
Old Jun 12, 2005 | 10:10 PM
turboedv6's Avatar
turboedv6
I know what an FRC is but what is a vert, when did they start making FRCs?
Old Jun 12, 2005 | 10:11 PM
turboedv6's Avatar
turboedv6
Never mind that site told me
Old Jun 13, 2005 | 08:38 AM
Hundoracer's Avatar
Hundoracer
That site is exactly what i was looking for! Thank you!
Old Jun 13, 2005 | 11:24 AM
IllinoisCorvette's Avatar
IllinoisCorvette
The Difference is quite large. In Jan. of 1998 the C5 had MANY internal changes. I would buy a 1998 made after Jan of 1998 ONLY. Always try to AVOID buying a first model year Corvette at all costs. The mid to late model year 1998s are like two different cars compaired to 1997s and pre Jan of 1998 built 98s. I would only buy a 1999 or newer C5 if I were you just to be on the safe side. Also AVOID 2001 model year C5s these ate oil like crazy because of a ring problem.
Old Jun 13, 2005 | 12:15 PM
SteveDoten's Avatar
SteveDoten
Default i couldn't tell w/ hood closed
besides all the other links mentioned, the ebcm was moved in front of the engine instead of in the rear behind the mid stowage comp. mid year '98, i don't know what month/day, so if you see a c5(that isn't heavily modded, ie-fuel sys)w/ 2 fuel lines and the ebcm mounted under the hood then it's definetly a '98 as the '99s went to the one fuel line returnless sys--ebcm=electronic brake control module
Old Jun 13, 2005 | 12:51 PM
FRC's came out in '99 and '00, then changed to the Z06 model.
To Difference between 97-98
