HUD not working?
Old Jun 13, 2005 | 08:01 PM
sandmanusd's Avatar
sandmanusd
Default HUD not working?
I have driven a Z06 before, and it seemed like it had the "1 to 4" light on the HUD, I don't get that light on my HUD, along with the Shift light... is there a way to modify the output on the HUD?
I can see the "1 to 4" in the HUD, it just doesn't light up when the "1 to 4" does on the dash board..
Old Jun 13, 2005 | 08:32 PM
MalaysianMenace's Avatar
MalaysianMenace
Weird - could it be that you need a new HUD?
Old Jun 13, 2005 | 08:34 PM
ronniej's Avatar
ronniej
St. Jude Donor '06
I just read somewhere how you could turn the shift light on and off on the HUD. I'll see if I can dig it up for you.
Old Jun 13, 2005 | 08:51 PM
VLVETTE's Avatar
VLVETTE
Did you cycle through the different display options?
Old Jun 13, 2005 | 09:15 PM
HIZVETT's Avatar
HIZVETT
Are you sure it had "1 to 4"? I know it has a shift light at high RPMs but I dont know about 1to4.
Old Jun 13, 2005 | 09:34 PM
VLVETTE's Avatar
VLVETTE
Old Jun 13, 2005 | 09:36 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I've never seen a "1 to 4" light on the HUD...only on the dash cluster.
Old Jun 13, 2005 | 10:44 PM
vette020's Avatar
vette020
From: The best times of your life have not yet been lived. MO
I see it occasionally, in the HUD, left of the MPH. Also in the dash. But only if I take off and shift slowly.
Old Jun 13, 2005 | 10:47 PM
Mine has only shown the shift arrow, not the 1-4 message. I don't think it is supposed to show the 1-4 shift on the HUD display.
Old Jun 14, 2005 | 07:38 AM
sandmanusd's Avatar
sandmanusd
ohh, maybe I was imagining things... I could have sworn... I guess not though... thanks for replys
Old Jun 14, 2005 | 08:31 AM
roscoe118's Avatar
roscoe118
No "1 to 4" shift light on mine
Old Jun 14, 2005 | 08:41 AM
ArmyVette's Avatar
ArmyVette
No 1-4 shift light in the HUD.
Here's the text from the 02 owner's manual.
Shift Light (Performance SHIFT Light)
This light is used for performance driving to indicate that the vehicle’s best performance level has been reached to shift the transmission into the next higher gear. The SHIFT light will display at an engine speed of about 5,750 rpm (6,250 rpm on Z06), just prior to reaching the engine fuel cut-off mode. To better understand the vehicle’s power curves, see “Capacities and Specifications” in the Index.
HTH.
Jeff
To HUD not working?
