Dielectric Grease
Old Jun 14, 2005 | 12:17 AM
PaulyT55's Avatar
PaulyT55
Default Dielectric Grease
I want to put some dielectric grease on my weather stripping. The only kind of Dielectic grease I could find at Pep Boys was from "Permatex" and it's a little carded tube labled as "Bulb/Lamp & Electrical Connector, Dielectric Grease."
Is all dielectric grease the same, which is silicone grease?? Can I use this stuff or should I go get a tube from GM?
Thanks alot.
Pauly
Old Jun 14, 2005 | 12:24 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Your good to go. That's the stuff.
Old Jun 14, 2005 | 12:26 AM
NSTG8R's Avatar
NSTG8R
well that all depends .. do you enjoy flushing money down your toilet?
Old Jun 14, 2005 | 02:18 AM
Paras's Avatar
Paras
Thanks alot.
Pauly
Not sure if you got the right stuff but I need to do the same thing--please post on how and where and how much to apply... THX!
Old Jun 14, 2005 | 03:49 AM
probaja's Avatar
probaja
Thanks alot.
Pauly
Thats the stuff -
Old Jun 14, 2005 | 07:37 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Good to know, I need some
Old Jun 14, 2005 | 07:56 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
You're good. Less is best when applying the grease so be judicious when your squeeing that tube.
Old Jun 14, 2005 | 08:46 AM
dajael
Guest
Posts: n/a
I started to buy some Dielectric grease (from the dealer $$$) and the counter guy asked what I was using it for. I told him I wanted to use it on my weather stripping and he said, Why are you using something designed for use on electric components for weather strips?....and then he pointed at the can of "Weather Strip Grease" by GM.
Feeling stupid, I bought the GM weather strip grease instead...it comes in a can that has a small brush connected to the lid. I used it on my strips and found it to be way too sticky and thick.
Now I'm wondering if I should have gotten the Dielectric instead?
Old Jun 14, 2005 | 09:15 AM
v.vet's Z06's Avatar
v.vet's Z06
You can also get it in a small red and white pressurized can (CDC I believe), and on the label it says it is for electrical connections and to treat rubber O rings and seals.
Old Jun 14, 2005 | 09:49 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I belive the OM says to use the dielectric grease.
Old Jun 14, 2005 | 11:04 AM
Setpoint's Avatar
Setpoint
I use a Leslie pool product called "Pool and Spa Lube". It is basically DuPont Drytox. It was around $10 for a 3.5 oz tube. I believe this is a pretty good price.
Old Jun 14, 2005 | 11:51 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Be Careful
________________________________________ ____________________
[=StephenT]I belive the OM says to use the dielectric grease.
When you use this grease.....be careful not to get it on the glass, when you try to wipe it off it will streak and smear and drive you nuts tring to remove it.
Old Jun 14, 2005 | 11:57 AM
BEKS's Avatar
BEKS
St. Jude Donor '14
Ok no question is a stupid question right? So can someone tell me what this is, when and why one would use it. Thanks.
Old Jun 14, 2005 | 12:50 PM
PaulyT55's Avatar
PaulyT55
Thanks Guys!!
Glad to find out that I got the right stuff. It's carded in a clear tube, not much grease only about 3grams worth. $1.39 a tube so I bought like 4 tubes to do the weather stripping.
Was just curious to see if this was the same Dielectric grease as all the other stuff.
Pauly
Old Jun 14, 2005 | 04:49 PM
csexton's Avatar
csexton
Keeps the weather stripping soft and pliable. Good stuff!
Old Jun 14, 2005 | 05:00 PM
Zumin's Avatar
Zumin
I've pondered why it needs to be "dielectric" also, since dielectric means it won't conduct electricity (this is the reason you use it on electronics).
The pep boys guy looked at me funny when I said I wanted dielectric grease for my weather seals also, and mentioned most people use the spray silicone stuff.
Then I got home and realized I already had dielectric silicone grease in my computer parts drawer and took back the stuff from pep boys (since I couldn't figure out if the stuff I got from pep boys was silicone or not, which I think is the actual important part).
Old Jun 14, 2005 | 07:39 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Correct me if I'm wrong, but couldn't one use any silicon lubricant?
To Dielectric Grease
MDriveMode's Avatar
MDriveMode
Would armorall work?
Old Jun 14, 2005 | 07:57 PM
LoneStarFRC's Avatar
LoneStarFRC
You mean "Krytox? It's supposed to do a very good job; kinda pricey though.
Old Jun 14, 2005 | 08:37 PM
Humanoid 2.0
I just use 303 Aerospace Protectant, spray it on a cloth and then wipe it on.
