i hear how good aftermarket ones are compared to stock.there's hotchkis and, i think,gm t1 or something like that??or should i just get some z06 ones for my 01 coupe??how much should i pay for used ones(or new??),thanks.
Unless your doing serious auto Xing the Zo6 sways work real well on the street. Check with Fitchner parts department for a excelllent price.
And depending on the year of your Vette, you can order them with out with out the aluminum end links. If you have the plastic end links you will need to upgrade.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
What years had the plastic vs. alumimun end links?
I'll be doing the Z06 sway's this weekend, I have a 00' coupe base suspension.. so I will let you know my results (got the package from Gene @ Fred Beans) around $200 with endlinks.
thanks for the info.leo,so that would be 50 buck's and i pick them up,right??!! how can i "sway"you?? i have an 01 w/base suspension.So,i guess i need the end links,too?
Put mine on this year! 01 A4 Coupe and really improved the handling. For the first few times driving I had to adjust to alittle understeer. I love the results and would'nt go back to stock.
