Need HELP
Old Jun 14, 2005 | 07:51 PM
01vetteC5's Avatar
01vetteC5
Default Need HELP
hey guys i was wondering if any one knows what this means C1214 Sol Valve Relay Contact or Coil CKT Open
its whats settign off some cods and im not sure waht it means ? any one know and can please tell me whats wronge and is it a bitch to fix or what thanks
Old Jun 14, 2005 | 07:59 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Ok, I don't know squat about it, but I'm going to tell you what the manual says.
The solenoid valve relay supplies power to the solenoid valves in the BPMV. The solenoid valve relay, located in the EBTCM is activated whenever the ignition switch is in the ON position and no faults are present. Power is provided to the solenoid valves through the relay from CKT 1242 going into terminal D of the EBTCM. The solenoid valve relay remains engaged until the ignition is turned off or a failure is detected.
Conditions for Setting the DTC
DTC C1214 will set anytime the solenoid valve relay is commanded on and the solenoid valve voltage is less than 8 volts, and ignition voltage is greater than 10.5 volts.
Action Taken When the DTC sets
ABS/TCS are disabled
  • - ABS indicator
  • - Car icon (TCS indicator)
Messages displayed on the DIC
  • -Service ABS
  • - Service Traction System
It also goes on to say that you should inspect the wiring and connectors thoroughly. Failure to carefully and fully inspect wiring and connectors may result in misdiagnosis.
Sounds like a heavy duty electrical glitch to me. I'd take it to the stealership, but you can try....
Inspect fuse 20A ABS/RTD Maxifuse in the Underhood Electrical Center.
If fuse not good, replace, cycle ignition switch off/on/off and check fuse.
If fuse okay, problem is corrected.
Old Jun 14, 2005 | 08:02 PM
JACKAL0PE's Avatar
JACKAL0PE
If fuse not good...
Turn ignition switch off
Remove the 20A ABS/RTD Maxifuse
Disconnect the EBTCM
Connect the J 39700 Universal Pinout Box using the J 39700-25 cable adapter to the EBTCM harness connector only.
Do you have these tools and know what this stuff is? Do I need to keep going?
Old Jun 14, 2005 | 08:23 PM
01vetteC5's Avatar
01vetteC5
thsi is very help full but please keep going ----- i checked teh fuse it seems fine ??? also what wires doo i check ?????
Old Jun 14, 2005 | 08:40 PM
JACKAL0PE's Avatar
JACKAL0PE
Ok
Using the J 39200 DMM measure the resistance between terminals D and B of J 39700
Is the resistance within the OL (infinite) range? (I have no idea what that meant - Jack)
Remove the EBTCM from the BPMV
Connect the J 41247 Pinout box to the BPMV
Measure the resistance between the J 41247 terminal 7 and the BPMV case.
Replace the BPMV (Refer to Brake Pressure Modulator Valve (BPMV) Replacement (Rear mounted EBTCM/BPMV) or Brake Pressure Modulator Valve (BPMV) Replacement (Front mounted EBTCM/BPMV)
Is the replacement complete?
_________________________________
Install the fuse if removed
Using J 39200 DMM measure the voltage at the 20A ABS/RTD Maxifuse by probing between the fuse test terminals and a good ground.
Is the voltage within Battery volts range?
Turn the ignition switch to the off position
Using the j 39200 DMM measure the voltage at terminal D of J 39700.
Is the voltage within the battery volts range?
Replace the EBTCM - Refer to ELECTRONIC BRAKE CONTROL MODULE Replacement FRONT AND REAR
Repair short to ground in CKT 1242
Repair open in CKT 1242.
That's all there is. Hope that helped you some. I don't have a clue what I just wrote, but most of it made no sense at all to me.
Old Jun 14, 2005 | 08:42 PM
JACKAL0PE's Avatar
JACKAL0PE
It says that a thorough inspection must be made. I take that to mean ALL the wires. I'd certainly check the ones around the Underhood electrical center.
You say you checked the fuse. Did you use a meter or just eyeball it? If you just did an eyeball, I'd get a meter on it.
Past that, this stuff looks way too complicated unless you really know what you're doing. I'd be looking for a dealer. Sorry but that's all the help I can offer.
You might try PM'ing Patches or Evil-Twin, if anyone can help, they can.
Old Jun 14, 2005 | 11:41 PM
01vetteC5's Avatar
01vetteC5
thanks it was helpful
Old Jun 14, 2005 | 11:55 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
here is some more info on it. If you want any of the documents outlined in the attachement let me know.
File Type: doc
To Need HELP
