[IDIOT] Left my interior....
Old Jun 15, 2005 | 02:10 PM
georgec114's Avatar
georgec114
Default [IDIOT] Left my interior....
...lights on for three days.
Went out this morning to run some errands and the car is dead.
I mean nothing lit up. Took the DD for the run and came
back to jump start. Took a while but started.
After a while I closed everything down while I checked the wires
and connectors. Shut the door and the lights are still on.
Simple problem and I'm glad it wasn't something I had to run down
because electrical gremlins are the worst.
A reminder to all...Check the water in your battery. Most people never
think of it but they are not maintenance-free. At least not since they
switched back from the AGM batteries.
...George
Old Jun 15, 2005 | 02:16 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Not sure about all years but my Vette has:
Battery Run-Down Protection
Your vehicle has a feature to help prevent you from
draining the battery in case the underhood lamp, vanity
mirror lamps, cargo lamps, reading lamps, console or
glove box lamps are accidentally left on. If you leave any
of these lamps on, they will automatically timeout after
about 15 minutes. To reset it, all of the above lamps must
be turned off or the ignition key must be in ON.
Old Jun 15, 2005 | 02:51 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
What year is it??? Didn't everything shut down after 15 minutes???
Old Jun 15, 2005 | 03:20 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Old Jun 15, 2005 | 04:44 PM
BigJoe's Avatar
BigJoe
My bedroom is right next to my garage and I can't tell you how many times I've opened the hatch on the Vette accidentaly when moving my keys around. But never have I had the battery drain because the interior lights were on. They go out by themselves as others have said. Sounds like you have some other problem with the electrical system.
Old Jun 15, 2005 | 04:49 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Same here. Not to mention the times I accidently hit the "panic" button...
Old Jun 15, 2005 | 05:38 PM
I agree. They should go out in approximately 15 minutes of no other activity. If your's is not doing this, then you should get it checked out before your battery continues to go dead.
Old Jun 15, 2005 | 05:41 PM
yellow01's Avatar
yellow01
Rundown protecion?
I know for a fact I've run down my 2001's battery this way...haven't tried the '04
Old Jun 15, 2005 | 05:45 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I think all C5s have this. My 99 Camaro did and my 2000 Vette does
Old Jun 15, 2005 | 06:27 PM
georgec114's Avatar
georgec114
No...The auto shutoff on the lights mentioned work just fine.
I manually (though I don't remember) turned the interior lights
on with the dash dimmer switch.
That is not controlled by the battery saver feature.
Not to panic guys...But it did remind me to check the battery water level.
A few cells were low...George
To [IDIOT] Left my interior....
