Stealth Technology
Old Jun 15, 2005 | 06:12 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Stealth Technology
Here tis.
Was reading a laser detection article the other day and lo & behold the detection ranges for a car with no front plate, is much less than one with. Check out this site: http://www.laserveil.com/why-veil-works/
Go to the test data summery page.
The theory is sound on their product but I’m skeptical unless I can get independent data.
Anyone try this?
Old Jun 15, 2005 | 09:25 PM
Shylor's Avatar
Shylor
The main reason states have front plate laws are to use as targets for radar and laser. So it makes sense you have to be closer to a car without them to make contact for a hit.
Old Jun 15, 2005 | 10:16 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Old Jun 15, 2005 | 10:39 PM
LoneStarFRC's Avatar
LoneStarFRC
Various states have had front plate requirements for many years before lasers were ever invented. One of the attributes that a license plate has, front or rear, is that it is a relatively vertical surface for the beam to be reflected off of. Over the last few years, most states have begun using a reflective coating material on them which greatly enhances light reflection (headlights, streetlights, etc) and makes them more easily read at night. It is the same material being used on stop signs and many other highway signs, for the same reason. The material makes an even better laser reflector, but was not initially adopted for that reason. It just happened to work out that way.
Old Jun 20, 2005 | 04:57 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Default Sounds about Right
I'll to that
Old Jun 20, 2005 | 05:14 PM
Makes sense to me. The plate has to be a good reflection surface to bounce radar off of.
Old Jun 21, 2005 | 04:25 AM
Shylor's Avatar
Shylor
This reflective surface was around more than the last few years. Try decades.
Old Jun 21, 2005 | 04:58 AM
2fast4sanity's Avatar
2fast4sanity
Wonder if painting the plates with a flat clear would do anything.
Old Jun 21, 2005 | 05:06 AM
Shylor's Avatar
Shylor
Doubtful
Old Jun 21, 2005 | 07:57 AM
sandmanusd's Avatar
sandmanusd
Just watched "Myth Busters" where they tested all the old tales of trying to beat the radar/laser...
Busted every one of them, including the LED's, foil wrapped car, etc... cant beat the guns!@!!
Old Jun 21, 2005 | 11:41 AM
vizette's Avatar
vizette
You can't beat it, BUT the point of things like Veil, laser diffusers, and jammers is to decrease the range of detection. This gives you time to slow down and gives your detector (if you have one) time to alert you before they get a lock.
Jammers and Veil have been proven to work up to a certain range (depending on gun and jammer) but eventually there is a punch through.
-Rich
Old Jun 21, 2005 | 12:39 PM
sailohio's Avatar
sailohio
In Ohio, a State Representative proposed they eliminate the front plate. The only desenters were in the State Highway Patrol.
To Stealth Technology
