When changing rims....
Old Jun 15, 2005 | 07:46 PM
Autoworker's Avatar
Autoworker
Default When changing rims....
...do they need to put new seals, o-rings on the tire pressure sensors?
Old Jun 15, 2005 | 08:35 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Per your profile, it appears that your car is a '98.
If so, the answer to your question is YES - seals are probably dried our by this time.
As a note, if you have not had the sensors replaced, or repaired with new batteries, then do so before installing the wheels.
Old Jun 15, 2005 | 08:40 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I replaced my stock wheels (04) that were almost 2 years old several months ago. Reused the same rings and everything. No problems.
Old Jun 15, 2005 | 08:47 PM
ttaylor's Avatar
ttaylor
I changed the wheels on my '05 SRX and have had nothing but problems using the old seals.
Old Jun 15, 2005 | 08:51 PM
army2000's Avatar
army2000
St. Jude Donor '11
You need new o-rings, they are probably mashed flat and dry rotted by now. You can buy them from home depot for about $2. I would also recommend some of that silicon glue just for good measure. You don't necessarly need new TPS or to replace the battery. The battery life is designed for approximately 10 years. I would let them die first then replace as needed. You only need to break one bead to replace the TPS.
http://www.hunter.com/pub/undercar/TECHLINK/index.htm
Old Jun 15, 2005 | 11:04 PM
They are relatively cheap and since you will have the sensors off the wheel, I'd go ahead and change them. Good insurance against a leak.
Old Jun 15, 2005 | 11:15 PM
diyguy's Avatar
diyguy
Mine leaked after new tires/wheels were put on. Very slow leak, but within 12 hours, they would loose 8-10 lbs. Determined, I was able to use some 8 mm O-rings from Lowes. Undo the lock nut then hang onto the valve stem REALLY good while air goes out, then slide the o-ring over and thru the hole on the wheel so it backed up against the sensor and rim, then carefully put air back into them - pumped um up to about 45 pounds, wiggled the valve stem to help seat them, then put the lock nut back on - snugged it down and haven't lost a single pound of pressure since then. Didn't even have to break the bead to fix it.
It was a little nervous using tweezers and small screwdrivers to get the o-ring thru the hole without dropping the entire sensor into the wheel.
I would suggest this procedure ONE-WHEEL-AT-A-TIME, unless you have concrete blocks or jack stands, in case you do drop one. The tire goes flat very quickly!
To When changing rims....
