Ignition switch
Old Jun 18, 2005 | 11:04 PM
Baetke's Avatar
Baetke
Default Ignition switch
Left the key in the switch for a few days, battery dead. Is this common? Looks like the only way the car is turned off is if the key is out of the switch. Is this a bad switch or normal.
Old Jun 18, 2005 | 11:28 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Always remove the key.
Old Jun 19, 2005 | 12:28 PM
Baetke's Avatar
Baetke
Very good reply, tells me alot. Anyone else?
Old Jun 19, 2005 | 01:24 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Since inserting the key "triggers" the memory I would suspect that leaving it in would result in the battery ultimately draining. You don't mention any other problems that you've been having which might signal an ignition problem. You might try posting in the Tech section also.
Old Jun 19, 2005 | 01:42 PM
Baetke's Avatar
Baetke
Now that makes sence. Thanks for the comeback c5BlackBeauty.
To Ignition switch
