Exhaust plate installation?
Old Jun 19, 2005 | 11:38 AM
golddog's Avatar
golddog
St. Jude Donor '05 thru '24
Default Exhaust plate installation?
When installing your exhaust plate did you leave a little overhang at the bottom or installed it flush with the bottom of the plastic boot? (or whatever its called) Your installation expertise is appreciated.
Old Jun 19, 2005 | 11:55 AM
rickko's Avatar
rickko
Think about it from the point of view from angle it will normally be seen. Certainly not by anyone lying or sitting the ground.
Use a little tape to temporarily hold it in position then stand back and you'll figure it out.
..rickko..
Old Jun 19, 2005 | 12:29 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Mine sits flush with the bottom, just try it with some painters tape then mark the position and apply. Thats how I did it.
Make sure you clean the area real well with alcohol and let it dry.
Old Jun 19, 2005 | 06:58 PM
Gray Ghost's Avatar
Gray Ghost
..rickko..
That's the way I did it.
Old Jun 19, 2005 | 07:03 PM
b98's Avatar
b98
Old Jun 19, 2005 | 07:26 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I put mine flush with the bottom.
Old Jun 19, 2005 | 07:53 PM
Z0SLIK's Avatar
Z0SLIK
Yep, me too!!
Old Jun 19, 2005 | 09:04 PM
viperZ06's Avatar
viperZ06
little overhang on mine.
Old Jun 19, 2005 | 09:20 PM
csexton's Avatar
csexton
Old Jun 19, 2005 | 09:22 PM
AdamC5's Avatar
AdamC5
but seriously very little overhang - maybe 1/8th or 1/16th of an inch. So basically flush
Old Jun 19, 2005 | 09:24 PM
LB04CE's Avatar
LB04CE
Flush to the bottom.
Old Jun 19, 2005 | 09:52 PM
army2000's Avatar
army2000
St. Jude Donor '11
Go flush with the bottom and I would recommend having someone else help you out. Looking at the plate from 12 feet looks alot different from 2 feet.
Old Jun 19, 2005 | 10:57 PM
Mine is flush with the bottom.
Old Jun 20, 2005 | 12:39 AM
BrianWe's Avatar
BrianWe
I left about a half inch of overhang so it is easier to see. No problems after about 10k miles.
Old Jun 20, 2005 | 01:09 AM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
While the back end was in the air for caliper painting, I installed my exhaust plate. I used a paint stir stick and held it on the bottom of the "box". I held the stick so it was long from left to right, with a majority of the stick on the "box" with a little sticking out on the aft side. I used this ledge to rest the bottom of the exhaust plate on. Once it was centered left to right, I pressed it into place.
Old Jun 20, 2005 | 01:12 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
No over hang, that is drag when the pedal is to the floor. I found that lining it up with bottom of the lip made a perfect look from a distance and closer up. I think you find that lining it with the bottom will ensure that it isn't crooked. LOL!
GOOD LUCK!
Micah
Old Jun 20, 2005 | 10:03 AM
gredmer's Avatar
gredmer
1/2 inch or so overhang. Mine have the exaust pipe cutout area and fit perfectly.
To Exhaust plate installation?
