Shift Points-A4
Old Jun 19, 2005 | 09:46 PM
02bluez28's Avatar
02bluez28
Default Shift Points-A4
At what point dose your vette shift at WOT... 1-2. 2-3.. 3-4... A4 -273 rear end..
Old Jun 20, 2005 | 03:12 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Honestly, I keep my eyes open for HUA drivers when I run WOT ... haven't even noticed the shift points.
Old Jun 20, 2005 | 06:48 AM
Patman's Avatar
Patman
Before I had mine dyno tuned with LS1 edit, my shift points were way too low in stock form, only around 5700 (if you believe the tach) I had them bumped up to 6000 though. The LS1 likes to rev, even when bone stock. Your best ET will come from having your shift points as close to the rev limiter as possible (trust me on this one, I spent a long time playing around with shift points in my former 98 Formula)
Old Jun 20, 2005 | 09:09 AM
98Z51's Avatar
98Z51
My 98 A4 with 3.15's shifts at 6000.
Old Jun 29, 2005 | 10:27 PM
Greg5's Avatar
Greg5
Default Hitting the limiter
I ran the Predator program on my 02 coupe and although I set the shift point for 1st gear at 6000 rpm and rev limiter at 6200 the sucker is hitting the limiter at WOT. It will not shiftt at 6000 without me lifting first. All other gears work just fine. What in the heck is happening?
Old Jun 29, 2005 | 10:43 PM
mike348's Avatar
mike348
I have a predator and if I increase the mph anywhere over 42 it will ignor the rpm set point and go for the mph set point.The mph set is to extend 1st. gear at part throttle.
Old Jun 29, 2005 | 10:52 PM
02bluez28's Avatar
02bluez28
Not rpm but mph dose the A-4 -273 shift at?
Old Jun 30, 2005 | 02:35 AM
VLVETTE's Avatar
VLVETTE
I cant remember the 1-2 some where arond 40-45 I think but 2-3 was around 102 never stayed into it long enough for the 3-4
Switched to 3.42s: 1-2-- 30-35mph 2-3---78-80mph
3-4----125-130mph??? (Always let up before I get there)
Old Jun 30, 2005 | 09:16 PM
02bluez28's Avatar
02bluez28
I ned 3.42. this 2.73 sucks bad
Old Jun 30, 2005 | 10:07 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Roger that. Decrease your mph shift and it will shift!
To Shift Points-A4
