Mine fell out completely one day as I was washing/drying the vette. I found a shop that glued it back in for me and so far all is well. It's been about a year now. If it hasn't fallen all the way out, it should be easier to glue back in
If you don't mind me asking ... about how much to you pay to have it glued back on. I got some estimates today and they are saying like 900-1100 Canadian. That seems out to lunch to have a window glued back into place.
I did mine myself, I used JB weld on it and did it with the top on the car.
it's been about a year now and it's still looking good, only cost a few dollars for the epoxy.
I would suggest Goop, or silicone sealant if you can find a way to clamp it. But try the tape. Worst that can happen is it doesn't work. How much area are you looking at?
Happened to my son's 2000 vert and he had it re-glued with the top on. Lives in central NJ and I believe it cost him about $150. Holding fine after a year.
After calling a ton of places, I finally found someone that can do it. I had suggestions for replacing the top (From a dealer of course) to removing the top and rebonding it. Most places wouldn't touch it but I finally realized I didn't call Canada's largest Glass company.
Apple Auto Glass has a shop no more then 5 minutes from me and they also do convertible tops/upolestry and they will do it for $125.00CA.
He said it works 95% of the time and if it doesn't work the first time they will do it for free the second, thrid, fourth .... etc ... etc till it works.
