Downshift Braking ??
In anticipation of a track day once I tried to see if I could blip without double-clutching and decided it is too ingrained a habit to stop. I'd mess up worse by trying to change than if I just downshifted as usual.Matching revs before releasing the clutch provides identical engine braking - it just removes the clutch braking that burns up clutches fast. Double-clutching helps reduce tranny wear, or at least that's what I tell myself cuz I think it's
.Only downside was when I had my accident last year and my (now instinctive) heel-toe braking position made it so the bottom right corner of the brake pedal on the ball of my foot concentrated the impact on a small area and shattered three bones in my foot.
Oh yeah, and it also means brakes last longer but rear tires are used up quicker. This messed up my so-called tires for life program, since all 4 have to be worn equally to get them replaced. This is just not fair on a car where you can't rotate, but the dealer suggested I'd been doing too many burnouts to have rears at 2/32 and fronts still with 6/32 (OEM GYs).
Jim
I believe engine braking was a technique used by the old timers when there were no power brakes. I'm not sure it had any relevance then and it clearly doesn't have any now. I hope I didn't insult any of you old timers
I may not be using the clutch/engine to brake, but I'm going into that corner 4500rpm and comming out at 5000rpm like a slingshot -- That's what these things are made to do! And it gets the Geritol pumping through the veins pretty good, too.
Young Kids these days don't know a thing about a sports car
Well I am no race guru but Downshifting Is very importand if you are on a track taking corners like your dodging a bullet.
See I use best of both worlds... When I drive my ride around with my permagrin I use my brakes becouse there will be no need for pushing my motor/clutch/tranny etc. well on the other side when I go out to highway 9 or the track its very importand to revmatch (blip throtle to equalize clutch &engine Rpms) Letting the engine do the breaking for you will help alot on those tight corners.
I actually tested this... I tried running my car with breakes only and keeping it in higher gear through turns (3rd) after 20 min or so
after pulling over I noticed smoke comming out of my tires and brake calipers and my rotors wobble everytime i brake ! :o
Now I am not saying "use downshift for ONLY breaking I mean It keeps the car in a powerband therfor you don't use "as much" breaking as you normaly would which will upset your cars balance in a turn if you did !!... I have never taken a course so I wouldn't know but I did race bikes and even though i got twice as many rpms I belive the concept is the same also mastered the heel and toe on an 87' Toyota Tercel 4 speed manual couple years back! Lol I got it almost down in the vette the first 2 days so its not that hard.
For braking, you can downshift while rev matching and then let your foot off the gas--it will help you slow down.
Old school..And I was there back then,,,was to AID the brakes by simoltaniously applying the brakes as hard as you could and additionally add some braking force from off throttle engine compression. The trick was the footwork running both the brake and the throttle with the right foot. AS you decelerate the engine goes to lower RPM, and needs to be down shifted. This is when the clutch is pressed, and the throttle is blipped just enough to being up the revs to match the speed of the drivetrain in the lower gear and clutch re-engaged, then off throttle for more compression braking, repeat as needed.......Today we have HUGE brakes that work much better and can be adjusted for perfect front-rear balance, and that resist fade like was impossible 30 years ago. It is actually faster to decelarate today's cars with just the brakes and down shift/rev match to match the gear and RPM needed for power-on as you pass the apex and get the go juice flowing. It's similar to the old ways, except there is NO engine compression drag applied to the rear wheels. When I got my first Lotus Europa in 1973, it had small brakes and the norm on the race track and brisk street was to use compression braking. By the late 70s huge rotors and calipers were generally availalble and it was found that consistant and reliable 'tuned' braking with optimal front and rear bias would get the lowest lap times and the compression aided braking was phased out of preference. You still had to MATCH REVS when DOWN SHIFTING but it was not to aid the brakes, in fact it would upset proper optimal brake bias/balance, causing the rears to lock up, ...which will make you spin out.
Either way, old school or new.....have FUN!!!
Ask the CI 6 guys how I drive with an A4
I downshift for additional control of the vehicle also.
Use brakes = yes. Use engine =yes.
Use both = PermaGrin(tm)
Like me... Im 20 and drive the shyit out of my vette. Its an A4 though so I just keep it in drive. I downshifted all the time in my camaro because it was FUN. Didn't have any problems with that car, and it had almost 90k miles on it when I sold it. I did my best to rev match because it sounded better and felt better on the car. I try to have fun with all my cars. My little sunfire hasn't been washed in over 2 months, but occasionally, I'll drive it just so I can bang through the gears. It isn't fast compared to anything, but it still can be fun.
