Re-using the stainless inserts???
Old Jun 22, 2005 | 08:45 AM
Busa196's Avatar
Busa196
Default Re-using the stainless inserts???
I'm going to replace my front license plate cover and have the stainless inserts......I was wondering if any of you had to do the same thing, and if so, were you able to take off and re-use the inserts?? I don't really want to fork up another $60 for a set.
Thanks in advance.
-Busa196-
Old Jun 22, 2005 | 09:11 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
If you are very gentle, and they were installed with the double sided tape, you can get them off without bending or creasing them. Use heat to soften the glue (a hairdryer or heat gun will work), then carefully work a flat blade under them at one end and work slowly to the other end.
Old Jun 22, 2005 | 09:44 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
He said it all. It's going to be tough not to bend them while trying to get them off. Good luck take your time and lots of Goo Gone.
Old Jun 22, 2005 | 09:45 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
And scrape off old tape/adhesive & re-apply using the red, 3-m double sided tape (got it at Lowes). I did it w/ a few I gooned up during application and they've held up through a snowstorm that encased the front in ice.
Old Jun 22, 2005 | 12:55 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Hey StockMan,
Love that new sig pic. Nice angle...
Old Jun 22, 2005 | 02:43 PM
Busa196's Avatar
Busa196
Thanks guys!
Old Jun 22, 2005 | 03:29 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
My "R" was lifting in the back, because the wash mit would catch on the tail of the R. I lifted it off gently, (use a little heat) removed the old foam tape, cleaned with acetone and reapplied the new sticky back tape that matched perfectly that I got from an auto parts store. Trimed with an exacto knife and stuck it back on. Can't tell it from a "good job". Good luck!
To Re-using the stainless inserts???
