DailyDriver: steering wheel squealing when turned
Old Jun 22, 2005 | 11:01 PM
turbosupra18's Avatar
turbosupra18
Default DailyDriver: steering wheel squealing when turned
My daily driver (honda accord) is squealing when I turn the wheel right or left. Is this just low fluid or do i need to replace that belt?
thanks in adv
Old Jun 22, 2005 | 11:23 PM
Wisdom's Avatar
Wisdom
I'd check the power steering pump reservoir first. If it's low, then think about the last time you checked it. If it was recently, then look for a leak.
For a story - my oldest daughter's first car once had a leak in the high pressure line from the power steering pump. When the engine was running, the pump sprayed power steering fluid all over the engine - and that produced a lot of white smoke! But you couldn't see the leak with the engine off. And I couldn't figure out where the smoke was coming from, because I could never get a clear view of the leak due to the smoke. After two nights of looking and thinking, I finally brought it somewhere to get repaired. But I know what I'm looking for the next time it happens!
- Wisdom
Old Jun 22, 2005 | 11:28 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Did you mean to post this in OT?
To DailyDriver: steering wheel squealing when turned
