asp underdrive pulley?
Old Jun 22, 2005 | 11:27 PM
not08crmanymore's Avatar
not08crmanymore
Default asp underdrive pulley?
why do i want one of these in my car when i get my cam stuff in there???
Old Jun 22, 2005 | 11:55 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
good ?, i don't see the $$ spent to worth the few hp the pulley produces
Old Jun 22, 2005 | 11:59 PM
not08crmanymore
Default pulley
the pulley is part of the cam package.i am wondering what it's purpose is!
Old Jun 23, 2005 | 06:59 AM
not08crmanymore
what downside to the accessories running slower??
Old Jun 23, 2005 | 08:54 AM
2000BSME's Avatar
2000BSME
Not too much of a downside at all. Your accessories will probably live a longer life by a small percentage. You may have problems with the alternator power produced though. You might see more headlight dimming than usual at idle-if you call that a problem. It happens on my stock pulley car anyway. GET IT! It will be a good mod.
Old Jun 23, 2005 | 09:32 AM
Red Vamp's Avatar
Red Vamp
I was supposed to get it when LPE did my 485 hp headers/cam package in May. The underpulley was on back-order so I couldn't get it. I was told @ LPE that it adds about 5 extra rwhp because less power is "robbed" from the engine turning the belts in the stock setup. It was about a $300 extra. My engine did 427 rwhp on the dyno so I guess I'll just have to live w/o those extra 5.
Old Jun 23, 2005 | 09:36 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
So Vamp, what did LPE charge you for the entire package w/o the underdrive pulley (I'm assuming they did all the work)? PM me if you prefer.
Old Jun 23, 2005 | 09:48 AM
Red Vamp's Avatar
Red Vamp
I paid about $8500 plus transportation costs. But I put my deposit down in April and there was a slight price increase after that (about $600??). Check LPE's website. It is called the "top end" set up for 485/500 hp.
Old Jun 23, 2005 | 10:09 AM
not08crmanymore
Default 8500
SUPERCHARGER?no supercharger?
Old Jun 23, 2005 | 11:41 AM
Red Vamp's Avatar
Red Vamp
Nope. Cam, Kooks 1 3/4 long tubes, FAST 78mm intake, Blackwing, plugs, wires, polished ls1 heads, 160 thermo, and a few other LPE goodies.
Old Jun 23, 2005 | 01:06 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Should have given me the loot and I could have done it for 1/2 the cost.
RE: Underdrive pulley. $275-$300 for a few horses. I think that money is better spent with something that will give you a better bang for the buck.
I'm doing my cam in 2 weeks and I'm not doing the UD pulley.
EG
Old Jun 23, 2005 | 01:36 PM
not08crmanymore
Default no pulley
England,why no pulley?i having a cam package put in in a couple of weeks and they tell me,a pulley too.
Old Jun 23, 2005 | 02:00 PM
0EG@EnglandGreen
Supporting Tuner
Pulley makes practical sense because you have to pull the stock pulley to get the cam cover off. I just don't want to waste $300 on something that will net me minimal rear wheel gain.
Plus you have to buy a new UD bolt and new UD belts as well - serpentine and A/C = more loot.
$300 can get me 2 sets of chromemoly pushrods (32), for example, a set of roller lifters (16) or a downpayment on a Tigershark front fascia.
It just depends on what you want to spend your money on.
EG
Old Jun 23, 2005 | 02:17 PM
not08crmanymore
Default pulley
SO England,no real big deal if i don't get the pulley??and i think tigershark is shark bait!!!can get on the site for some reason!
Old Jun 23, 2005 | 02:23 PM
0EG@EnglandGreen
Supporting Tuner
Correct. The UD pulley is entirely optional.
Like I said, it just makes good practical sense to change it while you're in there doing your cam because to do it otherwise is cost prohibitive.
The Tigershark site has shut down and is going out of business.
But Tigershark is still for sale at other vendors.
EG
Old Jun 23, 2005 | 02:35 PM
not08crmanymore
Default pulley
i'm not sure i really like the idea of my accessories turning slower...and if i ever want a supercharger,i don't think the u.d.is good for that!i can't believe tigershark is closing down!!!wtf???
Old Jun 24, 2005 | 06:46 AM
molson's Avatar
molson
you can buy the U.D. pulley with an overdriven alt pulley if you are worried about your voltage dropping..
I am going to install one because I have heard about the stock pulley spinning off after being re-installed.
If you are going to have to buy another stocker it makes more sense to put that $ towards an aftermarket replacement that doesn't wobble.
Good luck whatever you decide....
To asp underdrive pulley?
Old Jun 24, 2005 | 07:02 AM
not08crmanymore
Default pulley
well,i talked to chris at ecs,as usual,he recommends the pulley and say's not to worry,so,it's a go!
Old Jun 24, 2005 | 07:08 AM
Dark-Knight's Avatar
Dark-Knight
UD pulley decreases the HP drain caused by underhood accessories. Labor to just put the pulley on is prohibitive for the few poines gained, so the best time to do it is during a cam install. Every little bit helps. It's all cumulative.
It's your car, do what you want.
Old Jun 24, 2005 | 07:15 AM
not08crmanymore
Default i'm getting it
decided to go with the pulley when they put the cam in.what the hell,i had to spend LOTS more money on my 95 to get to 400 hp!!!
