Rain-X question
Old Jun 23, 2005 | 01:20 PM
Litre's Avatar
Litre
Default Rain-X question
Hello all,
I applied Rain-X about a month ago (2 coats) and I will periodically get smudges. After using dawn + Stoner's Invisible Glass (repeatedly), the Rain-X is still on there. Is there a good way to get it off? I don't think I did a good enough job washing the windows thoroughly before applying the rain-X, and wanted to attempt to re-clean them before applying more Rain-X.
Old Jun 23, 2005 | 01:43 PM
tk97's Avatar
tk97
I did that to my cobra a few years back, worst thing I could have ever done I tried everything to take it off, and it still smudged. Once you apply rainx it's on for a long, long, long time. And you have to keep using the stuff if you want it to work.
Good luck
Old Jun 23, 2005 | 01:49 PM
HERK's Avatar
HERK
try some alcohol.
Old Jun 23, 2005 | 03:22 PM
BigJoe's Avatar
BigJoe
Rain-x is one of those products that you have to follow the instructions religiously. I've used it on every car I have owned in the past 6 years (about 12 cars) and love the stuff. But as stated above once on it is hard to get off completely. I'd put another coat on and see if that helps. My technique is: Apply the Rain-X, let it dry completely, then wipe a small area with a damp terry cloth towel followed immediately, while the area is still wet, with a dry terry cloth towel, rubbing until all the cloudiness is gone. You may have to redo the wet/dry routine a day or so later if it has patches of cloudiness. Then you are good for 6 months at least.
Old Jun 23, 2005 | 03:48 PM
TeamSpeed's Avatar
TeamSpeed
Love RainX, been using it for over 10 years now!
The trick is to apply it, let it dry/haze, and then wipe with damp rag, let dry, and wipe it clear.
If you want to remove it, try a mix of vinegar and alcohol.
Old Jun 23, 2005 | 04:36 PM
TAGVETTE's Avatar
TAGVETTE
I've used the stuff on all my cars. Makes a great difference when cleaning off bugs and such.
Sometime you'll get smudging if it's applied when the glass is warm or hot.
Old Jun 24, 2005 | 01:00 PM
BUK VETT's Avatar
BUK VETT
I think your question is in regards to cleaning your windshield a few days/weeks after the Rain-X has been applied - here's what I've found -
I also use the Stoner Invisible Glass but after cleaning the windshield I will see streaks from the Rain-X - kind of like the windshield cleaner "Re-activates" for lack of a better term - the application process of the Rain-X. Just wait until it dries completely and buff your windshield with a dry lint-free cloth just like you would after applying the Rain-X to begin with. You could spray window cleaner all day and you'll still have smudges (trust me). The key is to clean the windshield, let it dry and buff out the smudges with a clean dry lint-free cloth.
Old Jun 24, 2005 | 01:04 PM
sailohio's Avatar
sailohio
When I used Rain-X, I found that wiping it on your wiper blades reduces the smudging. Let me know if it works for you.
Old Jun 27, 2005 | 10:06 AM
vetdude's Avatar
vetdude
This explains everything. I just picked up an '00 MY convertible with 4500 miles on it. Everytime I try cleaning the exterior glass with anything (Windex; Stoner's; Sprayway, etc.) other than a damp cloth followed immediately by a dry cloth, it's a streaky smeary mess. Never had this before with any off my cars, including the Vettes. There has to be a way to get this stuff off. Any tips appreciated!
Old Jun 27, 2005 | 11:27 AM
diverdan's Avatar
diverdan
I've never had the problem you describe, even though I've been using RainX for years on all my cars. The only smudging I have seen is when reapplying the RainX, sometimes the dry buffing towel will leave a smudge. The afformentioned damp towel will remove it or it will be gone the first time the windshield gets rained on.
BTW, I reapply about every month; I like it super slippery (and the RainX wipes make it really easy).
Old Jun 27, 2005 | 11:39 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I remove it with one of those kettle steamers. You can watch it puddle under the temperature of the steam then it wipes right up. Also good for removing stubborn hard to get off tinting. Once you get it all off with steam, a gentle wipe with unscented amonia will get rid of all the crude that has etched the glass.
To Rain-X question
