Active Handling
Old Jun 24, 2005 | 01:26 PM
Darrell '98's Avatar
Darrell '98
6th Gear
Default Active Handling
About a year ago I got a "service active handling soon" message. Stopped the car and turned off ignition. Message did not reappear upon restarting.
Same scenario last week. Anyone else have this problem?
Should I spring for the $90.00 diagnostic or wait and see if message gets more frequent?
All imput appreciated.
Thanks,
Darrell '98
Old Jun 24, 2005 | 01:42 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Welcome to the Forum, Darrell....first post!
Regarding your question - I suggest you query the computer and see if there are any codes that related to the active handling. Here's a link to a page that tells you how to do that and deciphers the numbers that will appear. Once you have the codes (if there are any, and I think there will be some) you might be able to determine what wrong and decide your next course of action.
http://www.corvettedoctor.com/1997-00_Codes.htm
Old Jun 24, 2005 | 02:10 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Welcome aboard!
I also agree that you should pull up the codes and see what the computer is saying and if there are any active codes. Once you do this once or twice, you'll find it is pretty easy. I also bought the service manual (actually a three volume set) which has each and every code in it and how to troubleshoot each (usually requires dealership equipment).
I wouldn't take the active handling fault lightly though. If it has problems, you may lose the safety net at best, or it may adversly impact handling at worst.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jun 24, 2005 | 03:55 PM
Darrell '98
6th Gear
Default blacksedan87
Thanks for the welcome and the web page.
Darrell
Old Jun 24, 2005 | 03:58 PM
Darrell '98
6th Gear
Default subdriver
Thanks for the welcome subdriver. I got a web page from blacksedan87 and will check out the codes.
Darrell
Old Jun 24, 2005 | 05:18 PM
istsme98's Avatar
istsme98
welcome and good luck with the problem
Old Jun 24, 2005 | 09:19 PM
C66 Racing's Avatar
C66 Racing
Darrell
You're welcome and good luck. Hope you get it sorted out okay.
To Active Handling
