NJ state inspection question with headers
Old Jun 24, 2005 | 05:51 PM
DBL001's Avatar
DBL001
Default NJ state inspection question with headers
Any guys from Jersey put long tubes on the car and still pass state inspection? I have an 01 and would like to eliminate the pup cats (but I guess there needed to heat the cats) and put long tubes on with a Z06 exhaust
Old Jun 25, 2005 | 11:54 AM
DBL001's Avatar
DBL001
ttt
Old Jun 25, 2005 | 01:18 PM
MisterC's Avatar
MisterC
In Texas they hook up to the PCM and do not make a visual inspection. My 01 has headers and all the O2 sensors give readings that are within limits, thus passing. So, I'd guess if you are not or have not had any codes pop up, it will probably pass. Not being a Texas expert, I will certainly monitor this post to see what others have to say.
Old Jun 25, 2005 | 03:51 PM
markcz's Avatar
markcz
Does Jersey shove the sniffer up your tailpipe? If so, then you at least need to get some high flow cats. They should be enough to pass the test once the car is warmed up.
Old Jun 25, 2005 | 04:23 PM
1BAD-LS1's Avatar
1BAD-LS1
I just passed with headers and hi-flow cats, see the sig for details...
Old Jun 25, 2005 | 05:32 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Bring it to your local shop and ask them. I believe that they just hook it up to the computer and as long as there are no codes you are good to go.
Old Jun 26, 2005 | 02:40 PM
DBL001's Avatar
DBL001
Yes they do put the sniffer in the tail pipe, But I think I will get by with the info I got from everyone on this post, thanks to all
To NJ state inspection question with headers
