I lowered my c5 today, i took the bushings and bolts out of the rear and cut all of the bushing except for one little round piece (if you know what im talking about) i did it all on every one... put the bolts back through, and left about 2 threads showing... it lowered my car pretty dang good ,
Questions:
has any one did this?
If so, do u like it, and have you had any problems?
also how can i lower the front, i have the z51 suspension?????
Questions:
yeah, the link above was what I went off when I lowered my front the other day. Very useful link. Definetly alot harder than the back but it certainly made the car look alot better. After a couple days the front settled on the new adjustment of the bolt and lowered another 1/2" or so... looks great, definetly worth the 2 hours it took to do
I also lowered mine today...but all I did was turn a few screws. I didn't cut bushings. Don't the bushings serve some purpose? What effect does cutting bushings have other than make more room for lowering? Anything negative?
What screws did u turn and what not... thats a great link by the way... i think i might go by that if a few screws being turned dont work, so i want to see what screws i can adjust with
well the first time i jacked up the front, took off the wheels, and just tried lowering the car by adjusting the 10mm bolt on the leaf spring(make sure you set it to loosen. Its reverse threaded). This lowered it but not enough. The next day I followed that link and actually took all the other parts apart(all this must be done to get the bolts and bushing off on the fronts). Takes awhile but its definetly worth it man
Ok i guess i will go at it tommorow , but if i dont like it for some odd reason i can repurchase the bushings correct... also what about camber????
FRONT
1) Jacked it up, out on stands and took off front wheels.
2) Used jack to lightly support leaf spring.
3) Used 10mm wrench to turn front bolts counterclockwise 4 turns.
4) Wheels back on and torqued to 100 lbs
5) Took car off stands.
REAR
2) Held top nut on bolt with 13/16 in. wrench and turned the bottom bolt head clockwise 5 times with 18mm socket wrench.
3) Took car off stands.
Hopefully car will settle a bit without getting too low.
FRONT
REAR
THANKYOU. Almost forgot to remind him about that. Definetly need to use a jack to lift the leaf spring up a bit higher otherwise the bolts are EXTREMELY hard to turn...
Not a problem.
What kind of drop do you think I'll get after settling?
FRONT
REAR
I dont think just loosening the bolt up is gona make that big of a difference on my car... but i dunno... how much did it lower yours???? i think im gona cut the bushings
I really just did it this evening, so iti s a little early to tell. It appears to be a bit lower...but not too much. I forgot to measure height before lowering.
Ill tell you, I did mine last sunday in about 30 min..... easiest mod Ive ever done on any of the four vettes Ive owned. I didnt even have to remove the wheels front or back. I was really suprised at how easy of a job it was.. It took a bit more time for the front but Ill I did was put the car on stands take the jack and used my small block of wood to protect the leaf spring ,placed the jack and jacked up the spring untill it gave me enough space to loosen and adjust the 10 mm bolt.... hell like I said and that took only a few min each side. Im not 4x4ing any more
Update - Day 1, 50 miles driven and now visibly lower...I like it. I may upgrade the suspension...not that I feel it necessary because of lowering...I just want to do it.
Although I have read 4 thousand posts on lowering on stock bolts, I have never heard an answer to this question.
TTT for my curiosity
Adam,
The bushings are there to cushion the ride as 1bad97 will find out.
The rears should never be cut, in my opinion. Longer bolts work great.
If you can only lower the front a little over 1" even with cutting the bushings then why lower the rear 2". The rake is now off. The shocks at 2" drop probably do not work properly either. Alignment is also probably way off.
Dave
Adam,
Dave
Thanks Dave! Excellent information - exactly what I was looking for
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
As corvette dave says, the bushings are there for a smoother ride. In order to get the look I was after I completely removed my front adjusting bolts. With the Z51 suspension that I have some bumps in the road were rather jarring. This was with the Goodyear run-flats. It rides much better now with non-runflats.
When I lowered mine (removed front adjusting bolts and replaced rears with longer bolts), it didn't seem like it needed an alignment. Ran straight and true as it did before lowering. My runflats were getting bald and I was due to replace them soon so I really didn't care anyway. Well, I was under the front of the car the other day replacing a turn signal socket and noticed that the camber was off quite a bit as the insides of both front tires was gone. It's been said a thousand times but I'll say it again...Get an alignment after 100 or so miles!!! You won't regret it.
