Help bad fuel guage???
Old Jun 27, 2005 | 11:01 PM
Intimidator3's Avatar
Intimidator3
Default Help bad fuel guage???
Yesterday I noticed that after I filled up with gas that my gas gauge was reading that I was on "E". My DIC even indicated that I was on reserved fuel and then after.. I was low on fuel. I was on a cruise so a friend of mine disconnected the positive connector and that solved the problem for a few minutes... only to have the problem repeat it self. Does anyone know of a fix for this or do I have to take it to the dealer???
Old Jun 27, 2005 | 11:05 PM
AEmedic's Avatar
AEmedic
Lots of members swear that a few tanks of Chevron Super w/Techron will cure your problem...
Old Jun 27, 2005 | 11:06 PM
BT-01-vette's Avatar
BT-01-vette
If you have Chevron gas in your area use it. Techron wrks well and so does BG44K. Wal-Mart has Techron and you can find 44k at a local dealership. I use 44k once a month and have not had any more issues.
Old Jun 27, 2005 | 11:13 PM
GrayC5's Avatar
GrayC5
Common problem. Here are just a few of the more recent threads here on this subject:
http://forums.corvetteforum.com/show...e&forum_id=103
Hope these help and good luck with the fix.
Old Jun 27, 2005 | 11:14 PM
lt1george's Avatar
lt1george
Default fuel "cleaner"
Give that BG44 K a try, it's the best. Good Luck. Save the Wave.>George
Old Jun 28, 2005 | 09:32 AM
SGT. PYLE's Avatar
SGT. PYLE
If you want to fix this problem, get B-12 Chemtol. Here is there site www.berrymanproducts.com
Old Jun 28, 2005 | 02:45 PM
sts57c5's Avatar
sts57c5
thanks
Old Jun 28, 2005 | 03:25 PM
zinbaad's Avatar
zinbaad
Sammy, thats an easy one. Disconnect both Borla exhausts comepletly, open the gas door. Use a 8 oz carpenters hammer and rap the gas cap 6 time hard. Reinstall Borlas, replace cap, close the door, then turn on car and say Holy $!#% it works. Repeat again if not
Old Jun 28, 2005 | 08:19 PM
SLPRC5's Avatar
SLPRC5
That is the ONLY gas I use after having the same problem once and it has never happened again..
Old Jun 28, 2005 | 08:21 PM
British's Avatar
British
Another vote for Chevron's Techron.
To Help bad fuel guage???
