Battery Disconnect?
Old Jun 30, 2005 | 08:34 AM
JLA's Avatar
JLA
Default Battery Disconnect?
I'm replacing the air intake this weekend. The instructions say to disconnect the battery. Is it necessary?
Old Jun 30, 2005 | 11:03 AM
Vette#2's Avatar
Vette#2
I wouldn't do it myself. You will throw a security code that locks out your radio. Then you need the reset code to unlock it. The reset codes vary so be sure you have yours if you do this
Old Jun 30, 2005 | 11:12 AM
jrose7004's Avatar
jrose7004
I didn't disconnect mine!
Old Jun 30, 2005 | 11:16 AM
rickko's Avatar
rickko
Old Jun 30, 2005 | 11:19 AM
Fuelie driver's Avatar
Fuelie driver
Not necessary!!!
Old Jun 30, 2005 | 11:41 AM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I've never understood why doing anything short of checking your tire pressure has recommendations of disconnecting your battery.
Old Jun 30, 2005 | 12:59 PM
I did not disconnect my battery when I installed my Blackwing.
Old Jun 30, 2005 | 02:54 PM
JLA's Avatar
JLA
Well........I did the intake this afternoon before I checked back here. I went ahead and disconnected the battery. I lost my tire pressure readings. Now it reads nothing for front and rear. Haven't checked the radio. I know there have been around 1000 posts on the stupid tire pressure reset, but....How do I fix that?
Old Jun 30, 2005 | 04:23 PM
JLA's Avatar
JLA
Radio is fine and the tire pressure readings came back after I took it out for a spin.
Old Jun 30, 2005 | 09:53 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
tire pressure won"t read anyhow unless you've been rolling a few minutes........
Old Jun 30, 2005 | 10:02 PM
csexton's Avatar
csexton
Old Jul 1, 2005 | 07:26 AM
shurite44's Avatar
shurite44
I have disconnected my battery many times with no problems with radio or anything else.
To Battery Disconnect?
