Anyone gotten this error code message on the DIC?
Old Jun 30, 2005 | 04:53 PM
mlinn1967's Avatar
mlinn1967
Default Anyone gotten this error code message on the DIC?
I recently got a Service traction control, service Active handling, and service ABS. The next day it was gone and doesn't reappear. Anyone ever gotten this? Do I have a problem, or was it a fluke?
Thanks!
Old Jun 30, 2005 | 05:11 PM
BUK VETT's Avatar
BUK VETT
I've been getting the same message - about 3 times in the last 3 weeks. after reading a ton of threads I think it may be a sensor going bad ??? I hope.
bump. . . .
Old Jun 30, 2005 | 05:21 PM
not08crmanymore's Avatar
not08crmanymore
Default message
i've gotten it a few times.i hit reset and mosey on down the line.
Old Jun 30, 2005 | 05:33 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
First, check your battery. Most of the time, that AC CRAPCO battery is to blame. Check you battery for leaks. Lift it up and check underneath it, check the battery mount plate in case it's leaking from the bottom.
If your sensor starts going bad (depending on which one it is) ... you get specific codes. i.e. I just got my car back yesterday, had a faulty streering sensor. It made the computer think I was in a slide, so I'd be driving straight and the ABS would kick in. I had a C1287 code.
Go to www.z06vette.com/IPC.TXT to learn how to read your codes.
To Anyone gotten this error code message on the DIC?
