Question about Remote
Old Jul 1, 2005 | 10:49 AM
White Six Speed's Avatar
White Six Speed
Default Question about Remote
My remote just quit altogeather. Nothing works. Worked fine last nite and nothing this morning. Is there any fuse any where on the car ? Dose it just quit like that when the battery is bad, no warnig. I put this in general, thought It might get answered by different members.
Old Jul 1, 2005 | 10:58 AM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
If you have a second remote, see if it works to eliminate any issues on the car itself. I dropped mine once and it quit working. I took it apart and there was a small break in one of the soldered circuits. Soldered it back and it works fine. Check the battery and see if that helps. Also check the owners manual about resetting the fob (remote). If it's shot, you can find them fairly cheap on E-Bay. Good luck - Zuti
Old Jul 1, 2005 | 11:21 AM
White Six Speed
I do not have an owners manual yet or another remote. How do you reset it? I am getting a owner's manual off ebay, I do not think it is the battery as it worked fine and then nothing. :o
Old Jul 1, 2005 | 12:03 PM
ScottN's Avatar
ScottN
St. Jude Donor '05
I found a couple of posts that might help you.
Resetting and Reprogramming Keyless Entry Remotes
Remote Entry Quit Working
Old Jul 1, 2005 | 12:40 PM
White Six Speed
Originally Posted by ScottN
Thanks I just tride it and my remote reset and now works.
Old Jul 1, 2005 | 01:32 PM
ScottN's Avatar
ScottN
St. Jude Donor '05
To Question about Remote
