Need Some Quick Help
I removed the bolts and the fuel rail moves a little, but does not lift. Call me stupid, but I don't get it.
HELP!!
Still struggling are ya! Remember my earlier post...If you look carefully, you'll notice that the entire unit will move a little once the bolts are lifted. That entire piece is what you're going to lift up, but also remember to do it VERY GENTLY. You'll literally hear it "POP" up. I believe there's 6 or 8 injectors for you to lift. No need to pull it completely upwards and out....Just enough to slide the plenum cover underneath once lifted. If it doesn't make sense, PM your phone #.
