Fog Lamp replacement
Old Jul 3, 2005 | 08:52 AM
vettman96's Avatar
vettman96
Default Fog Lamp replacement
Passenger side fog lamp is T/U. Does anyone have a p/n for the
replacement. I would like to have the bulb before I start this operation
as it looks like it may be hard to access.
Old Jul 3, 2005 | 08:56 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
access is easy...remove the black headlight surround...3 screws..reach down..twist and pull
alot of us have upgraded to the higher watt bulbs
Old Jul 3, 2005 | 09:16 AM
javamon's Avatar
javamon
What vendor did you buy the bulbs from?
Old Jul 3, 2005 | 12:11 PM
Lestat712's Avatar
Lestat712
I think the OEM was #893 but most folks replace with the higher watt #885. Please correct me if I'm wrong. Advance Auto has both in stock where I'm at.
Russ
Old Jul 3, 2005 | 01:27 PM
javamon's Avatar
javamon
Russ
Sylvania 899 is the stock bulb listed http://www.advanceautoparts.com/
Thanks!
Old Jul 3, 2005 | 02:10 PM
Lestat712's Avatar
Lestat712
Thanks!
Mine had 893's and replaced them with 885's which are 55 watts. Meant to say Auto Zone, not Advanced Auto. Do a search on the forum, there has been alot of posts. I'm sure others can chime in also. Hope this helps.
To Fog Lamp replacement
