Z06 front screens
Old Jul 5, 2005 | 09:42 AM
iceman47's Avatar
iceman47
Default Z06 front screens
Has anyone removed the self stick Z06 screens that cover the fog lights? I want to drill air holes in the fog light shrouds. I bought the screens from Mid America and the instructions said you have one shot, so I guess the glue is pretty strong.
Thanks,
iceman47
Old Jul 5, 2005 | 09:57 AM
Cajun99's Avatar
Cajun99
Take the double-sided tape off prior to install and use high grade velcro instead. Removal for cleaning or whatever you want to do behind them is then a snap.
Old Jul 5, 2005 | 09:58 AM
pewterwest99's Avatar
pewterwest99
I would get new adhesive before I tried to reapply the screens. Can't you remove the fog light surround completely? I think that I would attempt that before drilling. Best of luck on whatever you decide
EDIT: Looks like Cajun99 has a better idea
Old Jul 5, 2005 | 10:40 AM
2003vert's Avatar
2003vert
If they are on with the tape that comes with the units a high pressure car wash will probable loosen them enough to get them out. If you used good 3/M tape you may want to try a hair dryer ( carefully ) heat the tape up and pry them out. Honestly I would not take them out just to drill the holes. I did but can not tell any difference.
To Z06 front screens
