Hit the REV LIMITER!
Old Jul 8, 2005 | 12:38 AM
MiKe88's Avatar
MiKe88
Default Hit the REV LIMITER!
I hit the rev limiter in first gear automatic, whats the down side of that?
Old Jul 8, 2005 | 12:41 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I have done seeral times, I try not to do it often though.
Down side? Don't know for certain.
Micah
Old Jul 8, 2005 | 03:34 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Poor gas mileage...
Old Jul 8, 2005 | 05:30 AM
kendo347's Avatar
kendo347
Thats what the limiters there for. You will have no damage unless you downshifted into the wrong gear.
Old Jul 8, 2005 | 06:29 AM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Man, I left a holeshot the other day and was bouncing all over the limiter.... I simply couldn't shift into second fast enough.
In fact, I think the same thing happened the second time I was testing the gas pedal I was at Cruise In. (The first time I forgot to take the traction control off....hehe)
Opps, my bad.
Old Jul 8, 2005 | 06:30 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
There should be no damage from hitting the rev limiter. Just remember, we only have a rev limiter on the way up. If you down shift at the wrong time there is no protection.........be warned.
Paul
Old Jul 8, 2005 | 06:46 AM
Dark-Knight's Avatar
Dark-Knight
Should not hurt your motor.
Old Jul 8, 2005 | 06:54 AM
Should be no damage if you are accelerating - the limiter is designed to prevent any bad things happening.
Old Jul 8, 2005 | 07:42 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
With 4.1 rear StuzVette breaks loose and visits the rev limiter occasionally...
Old Jul 8, 2005 | 08:16 AM
T's's Avatar
T's
St. Jude Donor '06-'07-'08
Old Jul 8, 2005 | 09:23 AM
JoshVette's Avatar
JoshVette
That happened to me once......turned out my reaction shell (on the tranni) was cracked. Hitting the rev limiter didn't cause it, it was already cracked and it cause the trani not to shift.
No 2nd, 4th, or Rev.
Old Jul 8, 2005 | 12:40 PM
v.vet's Z06's Avatar
v.vet's Z06
Uh yeah!! Like maybe more then occasionally!!
Randy
Old Jul 8, 2005 | 12:50 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Randy
For a while i thought that was your shift warning.
Chris
Old Jul 8, 2005 | 03:38 PM
Vector's Avatar
Vector
Originally Posted by Red Racer
Poor gas mileage...
And it will slow down your times!
Old Jul 8, 2005 | 03:48 PM
2003silvercorvette's Avatar
2003silvercorvette
doing it a few times isnt bad but you have to remember that anytime you go to the point of over reving its never good even with a rev limiter your motor still wont like it lol
To Hit the REV LIMITER!
