[Z06] Plastic window molding replacement question
The drivers side molding has cracked in 4 places on my 03 Z06 and the passenger side is beginning to do the same.
I took it to the dealership this morning. They said they had never seen that kind of damage before and suspected I had put something on the molding to crack it. They agreed to order the part and have it repaired under warranty (we'll see how long that takes).
My question for you is - the plastic being broken is an annoyance that I'd like to have fixed, but I would rather have the cracked plastic than have the dealer screw up the weatherstripping, etc.
Is this something you've seen before? Would you let the dealership do the repair?
Thanks in advance
I have a friend that had his replaced and now he has wind noise after several visits to the dealer, so I left mine alone.
