[Z06] Question On 1/4 racing
Do i engage the line lock then apply gas while feathering off the throttle in 2nd gear or off the clutch quickly? I'm not looking to do much of a burnout since those tires need little or no burnout per micky thompson. I'm hoping to see mid 11's
www.msnusers.com/myzo6corvette
1. Drive around the water box - then back up to where your tires are in the wet part of the ramp, do NOT go all the way into the box. Give the tires a quick spin - one rotation, in 1st gear, to get them wet. (remember to take the car out of reverse - don't laugh, I have seen a few forget).
2. Drive forward to where you are just out of the wet part.
3. Stop, push the clutch in, and push the brake down all the way. Then engage the line lock. Release the brake, the line lock should hold the car.
4. Put the car in 2nd gear, rev up to about 3000 RPM's, dump the clutch and stand on the fun pedal hard. Wath the speedo, if the engine is racing and the speedometer isn't moving that smell is the clutch ...
5. Once you see that you have good wheen spin and the speedometer is up over 60 MPH or so count to 4, then release the lind lock while standing on the fun pedal. Let the car "walk" out of the burn-out.
6. As soon as you feel the tires grab let off the gas, put in the clutch, and roll forward to Stage.
Good luck ... and I think mid 11's on sticky tires on an otherwise stock Z06 is asking a bit much, especially for your first time with a stick.
Ranger has posted some good advice on shift points and launch techniques on this forum - do a search for his name, it is an excellent place to start.
And one more thing .. enjoy!
Les
PS .. you can test the operation of your line lock in a parking lot somewhere - to get comfortable with the feel of it when engaged.
Ranger's Launch Tech Thread
Les
Learn something new every day .. thanks.
Les
