I was wondering if anyone on here had their car wet sanded and then buffed out to remove the orange peel? I was thinking of getting it done on my black 99 and was wondering how much it would cost to have it done, a ball park figure???? Thanks for your help... oh yeah, do you notice a big difference? I did post this on car care but it seems more people read this general forum.... Thanks again...
I didn't have mine wet sanded, but I buffed it myself and the difference was amazing. I would imagine the results would be even better with wetsanding. You could always do it yourself and save some money. If you're afraid of hurting the paint just use a VERY fine grit paper and plenty of water (~4000 grit).
My car
Close up of drivers fender
you'll need a wet sanding pad.... looks like a rubber pad with holes in it. you can start with 1000 grit. as you sand you will see dull spots appear, those are the high spots. as the whole paint surface starts to get dull switch to 1500 grit. after the whole thing is dull go back over it with 2000 grit. Use light pressure with the pad as you don't want to have uneven pressure caused by you finger tips to make the surface uneven. Soak the paper for at least an hour before using it. use a spray bottle of water with a little dish soap in it to keep the surface wet and clean of residue. you can use a hose turned on lightly but I think the soap works better and you can see your progress better.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Just keep in mind that if you wet sand the finish, you're sanding the clear coat off the car. The clear coat is about the thickness of a sheet of newsprint. Good luck!
However, on a black vette, start and only use 2000 grit IMO. Also, have a hose and 3 buckets of clean water (with a little soap) handy and keep one bucket realy clean etc. Use blue painters tape and tape off the edges. A stiff sponge wrapped in sandpaper will work but I have also used a portion of a wooden paint stick wrapped in sandpaper.
Find out how much a shop will charge to buff the car if you sand it with 2000 grit yourself. Make sure they guarantee they won't leave swirl marks and you'll want to wash the car with dawn dish soap after you get her back and look at the paint in direct sunlight and thell them you're going to do that so they won't waste their time hiding any swirl marks with a glaze. Getting black perfect without swirl marks is tough. I just ordered new foam pads and a fine polish to remove swirl marks I still have from buffing with a swirl remover on July 4th. I'm building fiberglass panels and enclosures for my stereo project and I have sanding and woodworking dust all over. I can't keep my paint from getting fine scratches in it while I complete this project.
Personally I wouldn't recommend doing so. Our OEM paint jobs don't have a very think clear-coat so you wouldn't want to ware down any thinner than it is. The painters of typical show cars already have this in mind when they're painting for show quality. They will therefore apply many more coats of clear to afford them such an option. Don't misunderstand me, it can be done. But if you continue to polish your Vette as much as most of us, you'll ware through your clear coat sooner. If I were to do this to my Vette, I would wet sand the existing clear coat with 400 grit, then apply at least 6 more coats of clear ... then wet sand and buff that
To answer your question,Yes,I've done mine.Did it the first week I had the car.The orange peel on these cars is awful,and if you ever want to get your car "really" looking good ,you have to sand it first.I would never recomend this for a "do it yourselfer".Any good body shop should be able to do it for you.I start with 1500 ,then 2000,then two grades of compound and finish with a machine glaze on a foam pad .Stay away from the edges and any sharp creases.Keep it wet and clean and use a small squeegie so you can see what your doing.Based on the time I spent on mine I would imagine they would charge around $1000.Too bad your not in my part of the country,since I do car polishing as a sideline.
Well I found a guy that would wet sand, buff and then wax the car really cheap. However I am not sure I want someone taking sandpaper to the car, even though I would like the finish product. If it was a quality job. He did take out a few little scratches for me on the rear bumper corners with wet sanding and buffing though and did a great job. I want it done just leery yet.
I complained to GM. The dealership did a good job...under warranty. Everyone here was amazed.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
The cars from the factory come with 1 coat of clear on 'em. I wouldn't recommend wet sanding the car, even with 2000.
As you should be! Especially if he works cheap! Two big questions: Does he even have insurance? If so, would his insurance cover negligence in sanding all the way through your clear coat? Typically insurance will only cover accidents, not ignorance or stupidity. You better hope that he really knows what he's doing. Like I said in an earlier post, there is not very much clear coat to work with.
It's your call, but I feel strongly that you're making a big mistake. I really didn't want to post my negativity again, but I'd feel worse reading your post on how to fix it a week later. By the way, I paint Aircraft, Cars and Motorcycles as part of my daily job.
Best wishes,
Richard
I sanded and buffed both of my C4's my Impala SS and my C5 unless you get crazy I think you could get by doing it twice. I makes a big difference in the appearance Due to an accident I just had my C5 repainted and had 5 coats of clear sanded between coats and I'm gonna sand and buff it in a couple months
