spark plug replacement
Old Jul 10, 2005 | 10:54 AM
piezanno's Avatar
piezanno
3rd Gear
Default spark plug replacement
2This is the first time that I have wanted to replace spark plugs on the c5, how do I remove the plug wires? I have pulled on them and I cannot get the boots off. Do I need a tool?
Old Jul 10, 2005 | 11:03 AM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
not exactly sure on a stock LS1, but on mine, all i did was wiggle and pull the spark plug wires str8 off...they tend to kinda fuse themselves on with the heating cycles...
the plugs are easy as well...for me at least, took me about 45min all said and done. the only pain in the butt one was the one next to the oil dipstick...just unbolt the dipstick and ur good to roll...
make sure to use anti sieze on the plugs and some of that electrical goop on the tip of the spark plug where the wire plugs into.. makes for better contact.
Aj
Old Jul 10, 2005 | 11:30 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Pull harder, but grab it as far down on the boot as you can. Do not just pull on the wire...
Good Luck
Peace
Willfulone
__________________
..................Click for
Old Jul 10, 2005 | 12:46 PM
Old Rotor Head's Avatar
Old Rotor Head
If you've got a bunch of miles and live in a high temp zone just change the wires at the same time. May not be worth saving.
Old Jul 10, 2005 | 02:42 PM
99 vett babycar's Avatar
99 vett babycar
twist them as you pull - they'll come off.
Old Jul 10, 2005 | 02:48 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Aj
What goop?
Old Jul 10, 2005 | 03:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Jul 10, 2005 | 03:33 PM
Liberty2000's Avatar
Liberty2000
I think the two things you should have are anti-seize compound and dielectric grease.
Put a dab of the anti seize compound on the threads of the spark plug before you screw it in. I take a Q-Tip and put a dab of the dielectric grease on it and wipe it on the inside of the spark plug boot before I put it back on the spark plug. It may help prevent what you have now; the boot practically fusing itself to the spark plug.
Old Jul 10, 2005 | 03:37 PM
Liberty2000
I forgot to mention you can get anti-seize compound and dielectric grease at any of the auto parts stores like NAPA, Pep Boys, etc. Each comes in a tube.
Old Jul 10, 2005 | 06:43 PM
Merlin02's Avatar
Merlin02
Pep Boys has a tool for removing the spark plug wires. It's only a couple of dollars. It a piece of metal that has a handle and a 90 degree bend at the bottom and a slot for the spark plug and it hooks under the bottom lip of the spark plug boot. You don't have to pull on the wire or touch the boot at all.
Old Jul 10, 2005 | 08:08 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
Originally Posted by MyVetteDream
What goop?
LOL..my own goop...
nah, i meant the dielectrical grease... LOL forgot the name...
Aj
Old Jul 10, 2005 | 10:04 PM
Old Jul 10, 2005 | 10:52 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Change the wires if you're going to change the plugs. I went with the MSD's 8.5mm
To spark plug replacement
