Traction control system CODE C1291???
Old Jul 11, 2005 | 12:27 PM
dfitch9's Avatar
dfitch9
Default Traction control system CODE C1291???
I had Traction Control system fault that is not reseting. I went and got the code #C1291 which is "Open Brake Lamp Sw contact during deccel". Can anyone help???
2001 Navy Blue MN6
Old Jul 11, 2005 | 02:06 PM
Jeff Jeff's Avatar
Jeff Jeff
I had the same problem, the code is set when it senses rapid decelleration without the brake lights on.
I replaced the stoplamp switch on the brake pedal and the problem was fixed. It started out with my brake lights not working intermitently, then they would not work at all.
Old Jul 11, 2005 | 04:03 PM
dfitch9's Avatar
dfitch9
That would make sense because i had the car up to 70-75mph and then downshifted to help stop pretty quickly and then the fault light came on? I can't seem to reset the fault?? I haven't checked the switch and brakes lights to see if there is a problem but if the brakes lights are working ok then what??
Old Jul 12, 2005 | 12:17 PM
dfitch9's Avatar
dfitch9
I took a look yesterday and there are actually 2 switches on the brake pedal?? The upper switch has 6-8 wires and the lower one has 2 -3 wires, which one is it that you replaced?? Is the lower for cruise control and the upper for?? Thanks ina advance!!
Old Jul 13, 2005 | 10:11 PM
Jeff Jeff's Avatar
Jeff Jeff
One is for the brake lights, the other disengages the cruise control. The two switches are sold together as one piece, so you have to replace both (if I remember correctly).
Old Jul 13, 2005 | 11:41 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
To Traction control system CODE C1291???
